Hello
Firstly, what operating system are you using? I am going to give you steps to fix this in both xp and vista.
Windows XP:
Windows Vista:
First, right-click on the Desktop and select Personalize. In the dialog box on the right hand side, there should be an option called Change desktop icons.
On the Change desktop icons dialog box, go ahead and check the Recycle Bin box to add that back to your desktop. You’ll notice that there is a Full Recycle Bin and Empty Recycle Bin icon.
If you click Apply, your icon should now be back on the
desktop.
Really hope this can be of help.
Kind regards
Andrea
Hello
Don't know if you have tried this yet, but here is another suggestion.
Goto the registry
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Deskt
op\NameSpace and create a new key called
"{645FF040-5081-101B-9F08-00AA002F954E}" then set the (Default) entry
for this key to Recycle Bin.
Let me know if this doesn't work.
Kind regards
Andrea
Hello and thank you for using Fixya's services.
Right-click on an empty space on your desktop and select Personalize.
Click Change desktop icons located on the top left of the Personalization window under Tasks.
Check off the recycle bin in the Desktop Icons Settings window.
Click OK to save your settings.
Please let me know if you have any questions.
Hi Arthur, that's odd but let's try this solution:
There seems to be an update from Microsoft with many experiencing the same problem. Download the hotfix here and see if this works.
http://support.microsoft.com/kb/810869
Try my above link first!
That should work but if it doesn't, Microsoft has a workaround!
http://support.microsoft.com/kb/810869#W...
Hi!
I was checking to make sure the solutions I posted helped!
Jennifer
SOURCE: My recycle bin icon disappeared
Hello
Has your recycle bin gone missing from your desktop? Have you looked
everywhere to no avail? Don't worry! The following steps will help you
find and recover your lost recycle bin.
Right click any blank area of your desktop. In the menu that comes up, click on "Properties."
Click on the "Desktop" tab, and then click on the "Customize Desktop" button.
On the "General" tab, you will see a field with some standard desktop
icons. Click on the "recycle bin" icon and then click on "Restore
Default." Click "OK," and then "Apply," and finally "OK" again. You
should see your recycle bin back in its spot on your desktop. If your
recycle bin is still not appearing on your desktop, try the next steps.
Right click a blank area of your taskbar, point to "Toolbars," and then click on "Desktop."
Click on the double carets (>>) next to "Desktop" on your taskbar. Look for your recycle bin in the menu that comes up.
Drag the recycle bin from the menu to your desktop by clicking on it
with your mouse, holding the mouse button down, and moving it to the
desktop.
It is that easy!!!
Hi,I have just tried that but did not fix the problem. I am runing Vista Home.
Hi Jennifer 720, I have tried that but it didn't work. I then tried again and did a restart no luck again.
Arthur Tully.
Hi Lock and Jennifer, I have tried all ideas except the register one which I am too scared to try. None of the others have worked for me. Sorry.
Arthur Tully.
