Question about Dell OptiPlex 260 PC Desktop
Deell opti-plex wont boot
My system just keep flashing yellow light without booting. i have tried another power but still the same. pls tell me what to do
  • mrchuckz Jan 21, 2008
    when i power on nothing shows on the screen , the power indicator on the power button flashes yellow instead of green. its not booting. pls tell what to do
  • Anonymous Mar 14, 2008
    my computer won't start, when I push the power button, the light is yellow
    not green the computer won't starts, but the fan comes on. Please tell me what is the problems with the computer. Dell 5100 dimentions, thanks!
Try inserting your recovery disk. and make your cd rom your first boot device then press any key when you re-boot.
Posted on Jan 10, 2008
6ya staff
SOURCE:
Invalid boot file ini fix dell opti plex 270
bonvicin66,
Unfortunately, you are going to need to have a Windows Disk to run a Repair Install from the disk. If running a repair install does not resolve the boot.ini error you will need to format and reinstall Windows.
To get a Windows disk you can search the internet for a disk. If you are in the US you can try getting a disk from the link below.
Dell Backup Media Online Request Form
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell OptiPlex GX270 PC Desktop
Opti plex gx110
the cover being removed is a warning you can turn off in bios. if hard disk 0 failed you can check bios and make sure hd0 is still marked as your boot device, you should also open up the case yourself and make sure a cable has not gotten unplugged or moved. make sure both the power and data cables are plugged in if it's sata. if it's IDE make sure that the serial cable and the power plug from the PSU is plugged in. if it still doesn't work you can try a different plug from the PSU. if none of that helps you can download hirens boot cd or ultimate boot cd, boot to the disc and there are hdd diagnostics you can run to find out the actual problem. good luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jan 31, 2012 | Dell Computers & Internet
Dell opti plex gx280 high speed for processor fan
if it is the speed control your looking for you need to go into the bios and look for the bios setting for overclocking there you shoul find fan speed control you can usually fing it in the chipset configuration
Jun 27, 2009 | Dell Computers & Internet
Dell pc dimensio 5150 wont boot up
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (where power cord goes into unit).
Also try simply unplugging the unit from the wall outlet for a minute then plug it back in and boot it up.
Feb 14, 2009 | Dell Dimension 8400 PC Desktop
Blank screen
I just installed a geforce 6200 with heatsink, no fan, in my computer. Fry's is having a sale and for $20 after rebate, how could I go wrong? Upon first installation, the computer failed to boot.
THE FIX
Discovered modern computers will not even atempt to boot if the power supply is below the minimum requirement for the video card's recommended wattage. More proof that over-powered supplies are not an absolute necessity. I upgraded to 250w from the onboard 180w and it fired up. The rest was disabling the integrated video which i found out was compatible with geforce 5200 level of operations.
My system:
Dell Opti-plex GX260, cut to bare minimum since it was from a commercial business with 1G RAM after upgrade.
May 15, 2008 | XFX GeForce 6200 Graphic Card
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
No boot
check your pc cmos batteryit might low. there might be shorting on board because of fungers on edges of ad on cards ormemory.please clean it
Jan 21, 2008 | Dell OptiPlex 260 PC Desktop
Blank monitor after graphics card is installed
What motherboard do you have?
There will be somewhere in the bios to select which display device to use first.
Jan 04, 2008 | XFX GeForce 6200 Graphic Card
Dell OptiPlex 260 PC Desktop Logo
142 people viewed this question
Ekse
Clive
Clive
Alun Cox
