Question about Microsoft Xbox 360 Console
When i try to sync my controller the lights just rotate until the sync period is over and then return to the blinking stage
  • 87 Answers
If you try your pad on a friends 360 and if it works then the problem is in the rf board (power button board) this is where the wireless crystal is. replace the rf board you can find them on ebay cheap enough and you should be good to sync again. but bare in mind you will have to open your case breaking the the warrenty seal so if its less than a year old contact microsoft first. hope this helps.
Posted on Nov 17, 2009
Wii remote four lights solid
Sounds like it needs to be re synced with the system, Easy place batteries in Wiimote and turn on console press the red sync button in the back of the Wiimote and press the red sync button on the console it is now synced. If this fails it could be that the Wiimote has failed, if Wiimote had failed within warranty period of 90days from date of purchase return for repair or replacement if it is after warranty period discard and replace with a new Wiimote.
Jan 12, 2013 | Nintendo Wii Console
The brookstone stunt copter and remote donot sync
It would not sync. solution was to assume poor technical writing. step zero. turn the controller off. step one. plug in the battery to the copter. step two. QUICKLY turn the controller on. if you miss this small window of time, it is going to fail. The copter light blinks fast during this period, and if it slows the blink rate, then you have waited too long.
Dec 13, 2012 | Shuttle 9094 Emax Remote Control...
I have an xbox remote that wont sync to my xbox console. I used the remote with a different xbox console prior. Could this be the issue? How do i reconfigure my controller? I have pressed the search/reset...
Try this! Press and hold the button below the disc changer, also press the sync button near the charger port on the controller. Light should rotate clockwise and then blink twice. This will tell you which player you are.
Sep 16, 2011 | Microsoft Xbox 360 Controller
I have exactly the same problem as ammcgee What we can do? By ammcgee7 on Apr 20, 2011 My Nyko Wand for Wii will not sync properly. The two bottom lights for stay lit and device won't work at...
1) Open the battery compartment and there should be a small circular red button.
2) Next to the Wii's SD storage area there is a rectangular square button.
3) Hold down the red button on the controller and the red button on the Wii until the light on the controller stops blinking.
Sometimes it can take multiple tries to "sync" the controller with the Wii. Keep trying until the lights stop blinking.
May 07, 2011 | Nyko Wand? for Nintendo Wii
I just got the new s032g . i can't stabilize itand it's lookl ike no gyros installed. when it's come up it's start to move forward. any help? thanks, Erez
Make sure that when you turn it on, you place it on a stable and LEVEL surface until gyroscopes sync up and internal red light (not red/blue flasher in nose) stops blinking. This sets level heading for helicopter. If gyroscopes sync when craft is not level it will be trying to correct and will move forward or backward. If helicopter is level and blinking red light inside stops blinking after powering on and it still moves and wont hover. Then you have a defective board and I would return it to retailer and ask for replacement.
Hope this helps, let me know
r
Jan 23, 2011 | SYMA Toys industrial Syma S032 Ready to...
Tony Hawk ride board is not syncing with the console to connect and play the game. It the xbox connect button flashes and then when we press and hold the sync button, nothing happens.
Try to change your batteries even if they are full.
First press the Xbox Guide Button (located on the side of the skateboard) until it lights up and starts blinking. Then press the Sync button on the Xbox console so that the front lights start blinking. Now push the sync button on the skateboard (little button that is to the left of the Back button) until it starts flashing. Both the board lights and the console lights will blink twice when they are synced.
Jul 16, 2010 | Microsoft Xbox 360 Console
Won't start
You don't need drivers, apparently. On the base of the mouse, there's a red syncing button. Press both that and the black reset button on the base of the USB-connected charger. The laser light should become steady after a moment, indicating that the mouse is in sync with the laptop. (during this period the light should be blinking until it is synced) You may have to press the reset button multiple times. Hope this helps.
Jan 10, 2009 | Targus PAWM001U Mouse
I have a targus laser mouse mod. amw15us it will only right click will not left click am i missing or needing a driver to solve this have 2 of them they use to work fine
Try this: on the base of the mouse, there's a red syncing button. Press both that and the black reset button on the base of the USB-connected charger. The laser light should become steady after a moment, indicating that the mouse is in sync with the laptop. (during this period the light should be blinking until it is synced) You may have to press the reset button multiple times. Hope this helps.
Jan 09, 2009 | Targus PAWM001U Mouse
Xbox controller not working only has two lights on game pad
There should be a sync button right on the top of the back of the Xbox 360 controller. While the system is on. Power on the controller. Hold down the sync button on the controller, and then press and hold the sync button on the Xbox 360 console. Wait for a few seconds until the Xbox 360 controller lights stop blinking. Then test out the controller. Any comments of questions, post them by clicking on the add more details link inside of this question that you've asked.
Nov 16, 2007 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
