Goodman heater - appears to have no power however everything else around it is good and the breaker is fine.. does not have pilot light
  • 43,501 Answers
There is a switch on the door to the blower compartment. Either the door is not in place properly or the door switch has gone bad. Check out and make sure that the door is installed tightly and if that doesn't work then you can temporaily jumper out the switch to see if that is the problem. Make sure to disconnect power before working on the door switch as the main power goes directly to and through that.
Posted on Nov 18, 2009
Have a goodman gas pack and we lost power due to winter storm over night so now my unit is running but only cold air coming out
the pilot light runs from a very small gas jet and should not be affected by the power outage
however that is not to say that the jet may have frozen over and become blocked putting out the pilot light
AS the system needs power to drive the fan it is possible that without the fan and safety system working , the main gas supply solenoid would have shut down and that could have affected the pilot light
with the power reinstalled try lighting the pilot light
I would say that there would be a pizo starter on the front of the unit to light the pilot loght
Jan 24, 2016 | Goodman Heating & Cooling
Goodman gas heater model GUE080-4 . pilot lighs , but furnace will not . Electronic pilot lights & stays on for about 1 min, than shuts off seems main gas relay not switching on.need manual
Check roll out switches located around burner compartment.
there is a small square button between the wire terminals press firmly down on it to rest switches. If this solves the problem have the furnace cleaned and checked by a professional HVAC technician.
Bob
Jan 06, 2015 | Goodman Heating & Cooling
How do you light the furnace of a goodman ez 1625
We have not lit pilot lights ourselves since 1978 when they outlawed standing pilots in Ca for furnaces. We have electronic ignitions of spark oror hot surface ignition, neither of which can be manually lit.
Do you get any fan action if you flip the fan on from auto?if so, you have power and 24v control power too, I would start there.
Oct 31, 2012 | Goodman Heating & Cooling
SO basically my furnace just stop kicking on the heat at some point last night. I have it set on an auto temp around 70. By the time I noticed it being cold in the house I went up to the thermostat and...
I want you to do a simple test to verify that this is a thermostat problem for me. Start by removing the thermostat from its' mounting, next locate the red and white wire terminals place a jumper between them. If the heater now runs it is the thermostat went bad on you, if it does not run please check all connections both to the thermostat and to the furnace making sure that your wires have tight connections and are not broken. I am really leaning towards the thermostat being bad here. Sorry for the bad news but really strong feeling. Good luck
Jan 12, 2011 | Goodman Heating & Cooling
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
When the pilot lights the furnace the fan comes on and the fire goes out
could be a bad roll out switch a small thermal device located around the base of the burner ,locate on wirind diagram an ck with ohm meter should read closed , also could be to much gas presure if natural gas get the gas co. to check presure , also could be a faulty equipment ground from supply from breaker panel make sure well grounded and connections tight ,must have this gnd to keep gas valve open , hope some of these ideas help .
Dec 28, 2009 | Goodman GMS90703BXA Heater
Pilot light does not stay lit
check that pilot flame is in contact with the thermocouple the small copper cylinder if not properly burning against adjust if flame is good and the therm/coupl is not covered in soot(wipe clean if has build up)thermocouple gone bad replace
Oct 28, 2009 | Goodman GMS90703BXA Heater
Finding Pilot light on Goodman Model caf024a2a. Cannot seem to find the pilot light...The blower works but no heat.
i think the ca # is for the cooling coil unit - the heater should start with gmXXXXX - if your unit is fairly new - the pilot light electronically when thermostat calls for heat the unit will not light if the burner door is open
Oct 24, 2009 | Goodman Heating & Cooling
Too much flame on Rinnai Pilot light
On the end of the old pilot tubing there should be a small part. This "oriface" would have been inserted inside the pilot assembley in the same hole that the pilot tube screwed into. This small oriface has an extremley small hole in the end that reduces or restricts the gas pressure down to the low volume needed for a pilot flame. I bet that when you removed the old pilot tubing this oriface fell on the floor and rolled under the furnace. Find it, clean it and reinsert it. You will be fine. If you cannot locate it. You will need to buy a new pilot assembly. They come with a new oriface already installed.
Good luck..........
May 09, 2009 | Goodman GMS90703BXA Heater
Goodman Heater
This furnace has a diagnostic light on the control board found in the lower section of the furnace. Pilots are a thing of the past and your system has a glow ignitor. Look thru a small viewing port to see how many blinks are being displayed. Then remove the access panel and on the reverse side of it is a diagnostic chart that will tell you where to start looking. I would suggest you make sure the air filter is clean and that the condensation is being removed. Recycle the furnace with either the breaker or emergency switch. You can cycle the furnace with the front cover off if you tape the door switch closed. It may be easier to view the sequence of operation to pick up on where the fault is occuring.
Feb 24, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
