Question about HP DeskJet 960c InkJet Printer
Hi, It is possible to print with just one cartridge (black)? Thank you
    Sergeant:
  • 233 Answers
Simple answer, Yes.
Some machines you can even by black ink cartridges to go into the color slots.
Or just Larger black ink cartridges.
Hope this helps!
Posted on Nov 18, 2009
Is it at all possible to print on a Canon IP 4500 when the large black cartridge (for text) runs out? It ought to be possible, when all other cartridges are far from empty.
it is possible, when it shows catridge emtpy error press and hold the resume button for 5 seconds
also change the paper type from plain paper from photo paper so that the printer only uses the small black catridge for printing black docs
Apr 16, 2011 | Office Equipment & Supplies
Can i print with just black ink?
Hi there
No not can do it got to see all the inks sorry.
Feb 15, 2010 | HP Officejet 5610 All-In-One InkJet...
Want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
Dec 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printing problems
If you don't use the printer often it is possible that the ink gets dried inside the cartridge, hence you get the print out with low quality or blurred. We suggest you to use original HP cartridges and keep using the cartridges frequently.
Thank you for using Fixya.
Dec 12, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Changing ink default to BLACK
Not possible.
Epson uses the black cartridge mostly, but also adds color to the black printing in order to keep the color inks from drying in the print jets on the printhead.
They also make lots of money that way...
===sorry===
Sep 14, 2009 | Computers & Internet
My printer wont print black colour on pics or word docs
Hi, sounds like a dodgy ink cartridge. I would purchase a new black cartridge and fit and try that. Refilling epson cartridges isn't a good idea, if you can't afford originals, but compats instead of refilling them. a good place to buy is www.choicestationery.com I've never had any problems with their carts.
Dec 14, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
Wasting colour inks when printing black and white documents.
your printer needs all the cartridge otherwise it will not print
Aug 13, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Color ink is not working
Dear Black Rose
It is strongly recommended to change your colour cartridge.
Or it can be possible that you did not use your colour cartridge for a long time.
The nozzle of colour cartridge are blocked, if you did not use your colour cartridge for a long time.
Purchase a new cartridge if you can or go for a local refiller to refill (if possible) your colour cartridge.
Thanks
May 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Black dot in left margin.
If the black dots were not present with the old cartridge, then one can only suspect the new cartridge at fault. This rarely happens but it do happen. Chances are that there is a defect on the drum inside the new cartridge. You can visually check for this imperfection by removing the cartridge and sliding the protective cover to partially expose the drum (not in direct sunlight as they are light sensitive). There is a white gear at the side that you can manually rotate ( a bit stiff) to check for the possible fault. you can approximate the possible location by aligning a printed paper with the series of dots against the drum to give you an idea where to concentrate on.
Should this be the case, it is possible for you to return the new cartridge for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Samsung ML 2010 Laser Printer
HP DeskJet 960c InkJet Printer Logo
168 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
