Question about Nikon COOLPIX L18 Digital Camera
Shutter won't open
When I turn on the camera, the lens zooms out, but the shutter won't open. I have already replaced the batteries. What is the problem?
  • 641 Answers
SOURCE: Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Sep 10, 2007
  • 3 Answers
SOURCE: Lens Error!
Hi I use to be a camera technican for samsung repairing small camera's like yours.It is a very common fault 90% unfortunatley of lens errors are the users fault not the cameras. The lens error means the lens is jammed, usually by a slight knock while the lens is out or a bit if debri like sand getting into the lens's moving parts. If it is still under manufacturers warranty send it in for repair. If the camera is clean and looked after with no scratches, dints or abrasions on the lens or camera body you will have a chance to get it fixed under warranty for free. If it is scratched and dinted and the purchase value of the camera is around $250 it may cost you around that to get it fixed. Good luck
Posted on Jan 12, 2009
SOURCE: lens error
if the problem is due to the fact that u have dropped the camera on floor or put into water...then no other go you should change the whole lens array...contact your nearest service centre
Posted on May 13, 2009
  • 5 Answers
SOURCE: Nikson Coolpix L5 Camera will not power up.
i had someone with the same camera have a problem like yours but it wouldnt turn off and the only way to power the camera on was pressing the power and blue play button. i called nicon and they said try a reset all in the setup menu but this didnt work. i then played for a little longer with it and found if i gentally twisted the body of the camera it would turn on and off as per it should. so i removed the back of the camera ( coution very small screws) and found that the blur control ribbon cable for the top control board had come loose.take something non conductive and not sharp and carfully push the ribbon cable back into is socket. once i had done this everything worked ok.
a few other words of caution while doing this keep track of where the screws come from as they are different lenghts.do not have the batterys in the camera as the flash caps will be charged and if you touch the wrong thing ZAP you could get a nice supprise. and finally when repacing the back of the camera make sure the selector switch for movie , scene and camera is connected right otherwise you will have to remove the back again and fix this issue
i hope this works for you
Posted on May 14, 2009
t00nz
  • 4738 Answers
SOURCE: Shutter won;t open
Are you talking about the shutter, or do you really mean the automatic lens cover ? Take a look at this first to see if this is what you meant. Make sure you read the comments also for additional tips. I don't think it will be necessary to open it up to fix it. Stick with the easy tips, they should work, especially if this is happening occassionally:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Jun 05, 2009
Shutter open but won't turn on
You need to take your camera in for repair. Call the Nikon USA 1-800-645-6687 between 9AM-8PM EST, Monday to Friday for instructions for returning your camera for repair. They do not charge to examine your camera and estimate the repair.
Oct 16, 2014 | Nikon COOLPIX Cameras
My camera won't turn on and i have put new batters in it and it still won't turn on.
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it out slowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt.
Tips to open and check for common faults: http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related
Use some air to blow between the lenses to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must you try and open. If so check the voltage on the motor drive check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Oct 22, 2011 | Vivitar ViviCam 8018 Digital Camera
Won't turn on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 11, 2011 | Kodak EasyShare CX7330 Digital Camera
Lens does not always open, batteries run down quickly
the 520's are notorious for lens opening issues... I've had a few and any dirt or moisture in the lens shutters, and they'll get screwy.
Clean dirt with a little compressed air...not high pressure...
Batteries... set the resolution a bit lower, avoid alot of flash and zoom and you'll get better battery life... it's part the 520...carry spare alkalines.. always..
K
Jul 01, 2009 | Canon PowerShot A520 Digital Camera
Shutter won;t open
Jun 05, 2009 | Canon PowerShot A570 IS Digital Camera
Canon powershot s2 15 shutter won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
May 10, 2009 | Canon PowerShot S2 IS Digital Camera
Leica C1 -- Unusable, electronics haywired
hi,
your camera needs cleaning of lens and lens shutter; because some time dust particles gose inside and effect the alignment of lens and cause camera not working.
please give me good rating if the solution works
Thanks for using FixYa.
Jan 05, 2009 | Leica C1 35mm Point and Shoot Camera
Shutter issue
I experienced the same problem and took the camera in for repair - I was told the problem was with the motor on the zoom drive which had to be replaced. The shutter cover has worked fine ever since. Repair cost was about $150
Oct 05, 2008 | Pentax Optio 50 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Zoom lens
Oh I'd love to be able to see this one. OH well. What batteries are you using? If they are ordinary alkaline, then you should get a set of NiMH rechargable batteries. (As strong as you can find) If the problem continues, taale the camera into Nikon and send your friend the bill.
Apr 01, 2007 | Samsung Digimax A400 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
44 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
