Question about Motorola Mobility CLIQ Cell Phone
How do i delete pic from my sd card on morotola right form phone
How do i delete pic from my sd card on morotola cliq? Its keep sayin card locked.
Accessing files on a memory card using the phone
To access files on a memory card using the phone, perform the following steps: 1. At the Home screen, tap the Applications tab. 2. Tap Quickoffice. 3. Tap Memory card. 4. Tap to navigate folders and files.
Posted on Feb 02, 2010
  • calcalderon Feb 02, 2010
    hope this helps, had the same problem
Need to rest phone
To Reset & clear your phone
To reset your phone to factory settings and erase all
the data on your phone, press Menu > Settings
> SD card & storage > Factory data reset > Reset
phone.
Warning: All downloaded apps and user data on your
phone will be deleted. Data on your memory card will
not be deleted.
from the Cliq manual which can be found here
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/MOTOROLA_CLIQ_MOTOBLUR/US-EN/_Documents/Static_Files/CLIQ_UG_TMO_final_68000202382a.pdf
Mar 05, 2011 | Motorola Mobility CLIQ Cell Phone
How do i unlock my sd card
The only way to lock / unlock an SD card is with the little switch on the side, it's on the actual physical SD card itself. Take out the card and on it you will see a little switch you can actually "flick" one way or the other, one is locked, and the other is unlocked. It should have a little picture of a lock or the words LOCK on it to indicate which was is which.
Thanks
Tim
Sep 30, 2010 | Motorola Mobility CLIQ Cell Phone
My sd card is locked i cant save anything or even delete anything without getting a message saying sd card locked how do i unlocke it i already tried resetting my whole phone and still is locked help!!!!
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 15, 2010 | Motorola Mobility CLIQ Cell Phone
My cique says sd card locked help I can't do anything w pics how do I know what I can delete of sd card? It was in my blackberry before thank you
take the sd card out and there is a small switch on it that says lock...slide it the other direction and it will be unlocked
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 08, 2010 | Motorola Mobility CLIQ Cell Phone
CLIQ Cell Phone: i deleted some pics from my photo sect on the phon...
You can do 2 things.
1. Go to the app on your phone Quick Office,that is where you Sd Memory card files are located. Find what you like
May 18, 2010 | Motorola Mobility CLIQ Cell Phone
My cliq says no sd card detected wen there is a sd card. Why can't the phone detect it?
there may be some files corrupted in your sd card...you should formate your card and then try.. i hope this will solve your problem..
Apr 22, 2010 | Motorola Mobility CLIQ Cell Phone
Sd card is locked. how do i unlock it?
There should be a switch on the card itself, that you can slide over.
If you can put card in computer, you can right click on the card file, then go to properties and make sure that the"write only" file is UNchecked.
Jan 27, 2010 | Motorola Mobility CLIQ Cell Phone
How do I unlock my sd card on my moto cliq
RE: Unlock My SD Card
you need to unlock the phone and not the sd card. google how to unlock that phone model or visit this site to unlock your inspire .it is easy
For more information: http://www.techyv.com/questions/how-unlock-my-sd-card
Dec 30, 2009 | Motorola Mobility CLIQ Cell Phone
Unrecongnized file format
Hi there
Connect the camera to the PC, transfer the good pics to a folder on the PC, then use the camera's menu to format the card for use again, if you format the card before transferring the pics, you will loose them all.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | Kodak EasyShare C643 Digital Camera
Motorola Mobility CLIQ Cell Phone Logo
236 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
