Question about Fisher and Paykel GWL11 Top Load Washer
Trying to put a new pump on GWL11 does it go in from bottom?
  • 4 Answers
Yes it does very easy spins to the left theres a little tab that you have to pull back away from the motor unplug the 2 wires then reinstall
Posted on Nov 19, 2009
Drain pump removal on F&P GWL11
Try to drain all the water out before removing pump.
so motor and other parts don't get wet when you remove pump.
Mar 23, 2013 | Fisher and Paykel GWL11 Top Load Washer
GWL11 washer diplay won't light up or power on. drain pump leaked, replaced both, still nothing
your main board is out very come with a bad drain pump the new pumps and boards come with a fuse to stop this problem. water hit the pump and shorts out the board
Aug 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL11 fails to drain
I had the same problem. After bailing out the water, I tipped the machine and saw a knee high panty hose caught up in the fan on the bottom. I removed that, checked to make sure the fan could spin freely, and viola! problem solved!
Jun 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL11 Washer. Leaking from bottom. Doesn't appear to leak during wash cycle.
Have you checked the pump on the bottom of the washer? You may have to empty the water out of the unit by hand. Then tilt the machine backward. The pump is on the bottom and no tools are needed to remove it. If the pump is wet or rusted then that should be your problem. Another way to check the pump is to remove the 2 screw ib the back of the machine on the top, and remove the electronic controlls. inside the machine is instructions to turn the pump on.
Jun 18, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel gwl11 washer leaking and squealing
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
Jun 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
Won't spin or drain
remove as much water as possible lean washer back against wall pump is on front of tub bottom pump twist locks into bottom of tub ..no tools needed pull release tab back and turn pump out and clean
Oct 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel waher
If you call f&p they will fax or email you a parts break-down. 888-936-7872
Jul 14, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing machine faulty
needs a new pump and control maybe, its the most common sollution for that problem
Jan 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
77 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
