Loud noise that sounds like a train coming from drum
    Brigadier General:
  • 4,088 Answers
Check inside the drum for loose plastic bars that run front to back. You will need to release the top to tighten them if they exist. With top open, check the drive belt condition and replace it if it is cracked, pieces missing, or running loose. To release the belt, open a panel in back and release whatever creates tension in the belt (usually remove a large spring). With belt off, turn the drum by hand to check the rear bearing and whatever provides a bearing for the front edge of the drum--some dryers use plastic plates on the cabinet side for the drum to turn on, and others have actual rollers that the drum turns on. If rollers, check each one for missing pieces or warped surfaces of the rollers. If plates, check each one for wear through to the metal. Hope this helps.
Posted on Nov 17, 2009
What is cause of loud vibration noise
In most cases, vibration sounds come from which ever helps the drum to spin with no resistance, In most cases those would be drum support wheels or bearings depending on the model.
In some rare cases, blower or belt pulley could also cause similar symptoms.
Feb 11, 2015 | Dryers
Loud brake noise in 97 buick lesabre
When you had the drums off, did you inspect the shoes for excessive wear? And How do the drums look? Are they grooved? Can you be more specific about the loud noise. Does it sound like a grinding noise, or a screeching or pulsating noise. Is it lower pitch or high pitch?
May 04, 2014 | 1997 Buick LeSabre
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
We have a Bosch WFK 2401 that is approximately 8 years old. I am not sure what cycle it was on when all of a sudden a loud noise started coming from the washer. Sounded like a gear stripping. A loud...
Check to see if inner drum is loose indicating bearing problem..Also check two springs on top of tub evident with lid off they can snap/ good luck
Sep 29, 2009 | Bosch WFK 2401
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
Grinding when starts then a loud tapping noise, sounds like river dance on a train...
your front skid plates causing the drum to not be centered
Aug 10, 2009 | Maytag Dryers
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Everything works great -until the spin cycle - loud noise
Have you checked to make sure all three shocks under the tub are ok?
Dec 18, 2008 | LG WM-2277HW Front Load Washer
Top loading washer whirlpool
When we move the drum, even with our hand, about 1/2 way through, there is a loud clicking, popping type noise? Sounds like a train is coming through the house before it stops the cycle?
Dec 20, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
