Question about Polaroid TLA-01911C TV
Originally the orange (standby) light was visible but when tried to turn tv on, tv would not come on. I unplugged the tv and now there is no light visible and tv will not come on regardless of the outlet it is plugged into
    Problem Solver:
  • 19 Answers
Replace the power supply and inverter board - you can find a replacement from discount-merchant.com for $40 - just use the part # from the power supply board itself.
Posted on Dec 08, 2009
Called customer service at polaroid. they said the problem was within the tv itself.
Posted on Nov 19, 2009
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
When I turn off my Luxor TV in the bedroom the standby light flashes blue then orange. The lights are very bright & I have to get out of bed to switch off at the wall socket. What is the problem and...
The alternating blue orange light means you have put a reminder on for a program that hasnt started before you switched off, you need to remove the reminder before you turn the tv off then the light will be steady blue
Sep 14, 2011 | Audio Players & Recorders
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Sagem Axium HD-D45 S G4.T/2 of (HDD-D45F) range.from standby lights go red/ orange flashing, then the fan should start up and t.v picture appears. The fan does not start up and no t,v picture and the set...
Sagem Axium HD-D45 S G4.T/2 of (HDD-D45F) range.from standby lights go red/ orange flashing, then the fan should start up and t.v picture appears. The fan does not start up and no t,v picture and the set reverts back to standby
Aug 04, 2009 | Sagem Televison & Video
Problems with Jwin JV-DTV30 30 in. HDTV-Ready LCD Television
This sounds like micro glitch try unpluging the tv and all controlable inputs (PC, iLinks, or other such devices) wait 5 min then plug the tv only in and see if you have returned functions. if you should read the manuals of those devices to see if the control functions can be turned off.
Jan 07, 2008 | Jwin JV-DTV30 30 in. HDTV-Ready LCD...
JVC LT-26DF7BK won't turn on
Hi I had the same problem with my LT-26C31BJE. The TV just stuck in standby mode. If you tried to turn it on, it seemed like it tried to power up, but then reverted back to standby.
I solved it this way. I took the back off the TV (unplugged of course) and made sure all visible contacts were home (they all seemed to be). Also to the right of where the power lead enters the box there is a small fuse, 250V 6.3 W. I replaced this fuse and the TV now works fine.
Dec 27, 2007 | Televison & Video
Polaroid TLA-01911C TV Logo
164 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
