Question about HP LaserJet 4m plus Printer
I have a laserjet 4m plus and the print is ok but the page has a grey shadow on it. Any solution? Michael D Neal
  • HP Master
  • 32,281 Answers
This is a sign of a worn or faulty toner drum or a dirty fuser roller.
Clean the fuser roller, switch the laser off and let it cool down first and clean the fuser roller with a cloth with a some white spirit.
If the fuser roller is clean the the toner cartridge needs to be replaced (it contains the photo drum).
Posted on Nov 18, 2009
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
HP 4m+, has shadows of what's being printer on the left side of the page and is darker. The toner cartridge has reverse images on the roller. Is this a cartridge problem or ?
just remove the toner and try to clean the roller with tissue also clean the pressure roller inside.and see is there waste ink powder inside.just clean and try .if you still facing the problem then you have to show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 12, 2010 | HP LaserJet 4m plus Printer
Hp Laserjet 4 Plus printing very light - second post
Your description indicates that the problem is with the printer driver settings.
Go to Start, Control Panel, Printers and check the setings for Economode and ReT. The should both be off or Economode=off and ReT set to Med or Dark.
This should fix the problem. Let me know if this works or not and we can try something else.
May 03, 2009 | HP LaserJet 4m plus Printer
HP Laserjet 4M Plus
That sounds like a problem with your printer driver to me. If the wrong driver is used, then print codes that the other device uses will not be interpreted correctly by your Laserjet 4M Plus, which will cause it to beep. Check the driver on your computer to make sure that you are using one designed for any of the following:
HP Laserjet 4
HP Laserjet 4+
HP Laserjet 4M
HP Laserjet 4M Plus
(Either the symbol "+" or the word "Plus" may be used but most commonly the + is the non-Postscript version and the word is used with the Postscript version. Just as an FYI, the only two differences between the M and non-M versions are the ability to speak Appletalk and the addition of the Postscript module, which is in one of the RAM expansion slots.)
Mar 29, 2009 | HP LaserJet 4 plus Printer
Mac laptop hooked up to HP laserjet 4 plus gets error message:
This printer will not work with a Mac - it has no postscript.
The only laserjet 4's that work with Macs all have an "M" in their name - 4M, 4M Plus etc.
You might be able to get a Postscript personality module for the printer to effectively upgrade it to the "M" version.
Feb 05, 2009 | HP LaserJet 4 plus Printer
Printer not responding
Test the printer itself to see if it will print a configuration page. This page will tell you if the IP addresss is still intact.
Apr 17, 2008 | HP LaserJet 4 plus Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
Cannot print only one copy; prints the first page only . . . over and over again
Check the menu and got to printing options, it may be that the number of copies got changed, you can set it up to where it can make up to 999 copies!!!!! why that option is on there is a mystery.
Oct 04, 2007 | HP LaserJet 4m plus Printer
HP LaserJet 4m plus Printer Logo
255 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
