Question about Samsung SGH-J600 Cellular Phone
My phone will not allow me to ring in. or except calls or texts
Everything works ok except i have a limited service/ no service message on the screen - if i try to ring or text i get network error and emergency calls only.all was ok until about a week ago
U dnt hav 2 worry.Just switch off ur phone,remove ur sim card and replace it back,then switch on d phone.If it stil shows d same message,contact ur network service provider.
May 02, 2011 | Samsung Cell Phones
When i get a call or text i have no alerts such as a ring or sound
HI, HAVE YOU TRIED TO CHECK THE PROFILE YOU ARE ON? IT IS HIGHLY POSSIBLE YOU ARE PRESENTLY ON A PROFILE THAT DOES NOT ALLOW RINGING OR VIBRATING.
PLEASE TRY CHECK THROUGH ALL YOUR PROFILES AND SEE THE SETTING OF EACH ONE.. BECAUSE NOKIA FOR EXAMPLE WHEN YOU ACTIVATE "MEETING" AS YOUR PROFILE, IT WILL NOT RING NOR VIBRATE BUT IT WILL ONLY BE BLINKING.
CHEERS
Mar 04, 2011 | Samsung Jack Cell Phone
Double ring tone issue
Go to the same place that you go to to put it on vibrate and scroll down to set ring tones/alerts and sms text and change the settings the volume should be set to silent.
Apr 20, 2010 | RIM BlackBerry? Tour 9630 Smartphone
When someone texts or calls me my phone vibrates instead of ring
You probably have silent mode on. Try pressing and holding the pound or the star key. One of those will probably release silent mode, so that whatever ring setting you have can be used.
Nov 09, 2009 | LG RUMOR Cellular Phone
Internal Speaker Problem
Water damage is deadly. Your speaker is different from your earpiece speaker and that is the reason behind why you are able to hear your device ring as well as incoming txt messages. Since your device has been in contact with water-damage, more than likely the ear-piece suffered from that effect. There is no fix to water-damage devices, except replacing the phone as a whole. Thanks. Sorry for the bad news!
Mar 13, 2009 | Cell Phones
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
My sony erricsson w910i will let me send and receive texts but not ring or allow me to call out, if you ring my phone from another it sounds engaged.
It sounds like you phone has been barred or blacklisted on your mobile phone network. You should contact them to sort it out.
Apr 16, 2008 | Cell Phones
Unable to make or recieve calls
have a look your security setting under settings menu and go into the call barring section to click cancel all. try it and hope it can help!
Sep 11, 2007 | LG Prada KE850 Cellular Phone
Samsung SGH-J600 Cellular Phone Logo
24 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
