Question about Samsung LN-T4671F 46 in. LCD Television
HD LCD TV takes a minute to turn on + makes clicking sound
HD LCD Set is 2 years old and for the past 2 weeks it has been taking about 45seconds to start and makes a clicking noise as it tries to turn on, I have direct tv if that has any relevance.
    President:
  • Samsung Master
  • 1,779 Answers
Have the Power supply repaired ASAP!
Posted on Nov 17, 2009
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Dec 30, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Sound goes up and down
Sounds like a dry joint or a capacitor has broken down, you will need to take back off and check, just remember there is 240volts in the PSU of the system.
Jan 27, 2012 | LG 42LD520 42 in. HD-Ready LCD TV
I have no sound..TV is only 1 week old. ????Having to use 2 remotes because Bright House does not have a set up code for DYNEX
Tv have no sound?Tv is new,take it back were u bought it for a new tv for the replacement.Having to used 2 remotes for the tv don't work on tv or have no tv codes for the tv dosn't effect the tv sound.
Mar 22, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
My 32-inch lcd tv from sharp has no picture but audio works fine. No picture ever comes up, not even the "please wait" message. Whats going on?
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Dec 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
TV clicks constantly, as if trying to turn on/off.
Probably a bad main board or T-CON board or both. If you're trying to fix yourself, try disconnecting the cable (LDVS) from the small board (T-CON) at top center of the LCD panel and see if it still cycles. Note, be very careful with that cable, it is very delicate. If it still is cycling off and on, then it is probably the main board. A slight chance it may be the power board also.
Apr 04, 2009 | Samsung LN-S4051D 40 in. LCD Television
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Samsung LN-T4671F 46 in. LCD Television Logo
351 people viewed this question
Jerry Greenberg
Jerry Greenberg
