Question about Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000
I am looking for the eletric starter gear for the 4hp show blower the mfg was home lite it was purchase in the mid 80.
What could be wrong with my tecumsa electric starter
Did you take the starter off and put power to it?
Open Ended it? you mean you placed it up on the auger and took the bottom cover off? The drive gearing has nothing to do with the Starter. O would pull the starter and see if Mice didn't make a home in there
Feb 27, 2016 | Garden
Where is the fuse for the convertible located the top just stoped working mid way up lite blinking by the switch any ideas pls help
Owner's manual, troubleshooting, no manual, try filepeep.com or manualslib.com or MFG website, or their customer service email.
Apr 08, 2015 | Cars & Trucks
I put a starter on a 95 dodge dakota sport but the starter drive will not engage tne to the flywheel
There probably needs to be shims installed between the starter and the engine block to allow proper spacing for the starter gear to engage the flywheel teeth.
Dec 20, 2014 | Dodge Cars & Trucks
How to adjust a home lite mighty lite blower vac carburator "?"
Hi. This link,
http://manuals.homelite.com/documents?page=5
is to the homelite page where the manuals are, however, there are 4 different models of the handheld blower you have. Either way, if this is a really new model, there may be no way to adjust the carburetor, as due to emissions standards, there may not even be any idle screws, but if they do exist, the head ma be whats called "pacman", as it looks like a little....yeah...pacman.
Apr 25, 2014 | Homelite Mighty Lite Blowervac
Electric start just wines & dont start the snow blower
Pull off your starter and look at your gear on starter, sounds like it isn't engaging, may need to replace that gear on the end of starter
Nov 27, 2011 | Garden
Proper spark plug for homelite mdl ut2oo series weedeater
  • MFG Brand Name : Ryobi/Homelite
  • MFG Model # : AC00160
  • you can get them at any Home depot or any hardware store
Jul 04, 2011 | Homelite Mighty Lite Lawn Trimmer
Weed eater Feather Lite Blower - replacing pull cord -can't figure out how to get to it
This should help you out. Go to Poulon's website. Look for a tab to "order parts". Model is fl1500. That will take you to a page that you can look at the blower "chassis" to order parts. That shows you how the bottom housing goes together. You have to take off the bottom housing, the blower fan, the top housing. That should take you to the starter cord mechanism.
Good luck.
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=FL1500 Gas Blower Type 3&AFID=59
Nov 21, 2009 | Garden
1/4hp Craftsman Garage Door Opener only travels a short distance
of course... the plastic cap is more than necesary for the rpm sensors between the plastic cap is running, u need to buy a new plastic cap at www.aaaremotes.com
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000 Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
