Question about Acer Computers & Internet
Can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
  • Tom McCormick
    Tom McCormick May 11, 2010
    The beeps can tell you about the problem. Do you know what kind of BIOS you have? (Award, AMI or Phoenix ...) It should say if it boots at all. Are the beeps all the same? are there any pauses? Tell me more ...
  • 691 Answers
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
Check your ram I think
Posted on Nov 19, 2009
    Novelist:
  • 138 Answers
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Posted on Nov 18, 2009
Why does it keep rebooting?
OS is corrupt and needs to either be repaired or reinstalled.
Oct 20, 2015 | Dell OPTIPLEX 960 MT Desktop Computer...
4 bleeps dell inspiron 530
Remove and then reinstall the memory modules.,
Apr 06, 2013 | Dell Inspiron 530 Desktop Computer
I needed to re-install OS, etc on my Aspire 1360 and used the system disk and recovery disks. When I inserted the system disk for the second time, as prompted, all I got was four single bleeps at around...
Hi
please try pressing the ALT+f10 ON STARTUP
this may take you into the factory restore
if it asks for a password and you have not set one then the default is normally 000000 6 zero,s
then follow on screen instructions
if you have the option to save any files or pictures before you do this please do so if you need any saved as you will loose them if you do a complete factory restore
many thanks
Jul 18, 2011 | Acer Aspire 1360 Notebook
I turn on my acer 5736z and the very next moment it shows an error message saying " BOOTMGR is missing press Alt+Ctrl+Del " to restart and it keeps on doing this over and over again no matter how...
Corrupt OS.
Repair or Reinstall OS.
1. Insert your OS installer then restart your PC
2. In a system setup press many times DELETE or F2 and first boot CD ROM
3. after restart in a setup press ENTER
4. this will copy OS files, after restart
5. this will intall OS just wait to fill your product key and ect.
Engineer Tops
Apr 28, 2011 | Computers & Internet
My computer could not recognize cd/ dvd drive. No drive letter or anything.Tried everything but still nothing happened. My driver is working (there is light bleeping) but when i insert a cd, no action....
I had the same issue, not once but twice. Both times however, it required service technicians to fix, and actually replace the device. There was an additional issue however that may have started the decline in the first place. I am unable to get high speed internet, and as a result, many of my updates are interrupted and files slowly become corrupted. If this occurs often enough, it can actually corrupt your O.S. and browser! I had to replace the internal CD/DVD in my computer twice, and the last time, they had to wipe my computer and reinstall the O.S. Not the best of news. What I do now to avoid the problem, is to disable automatic updates, and only update elsewhere where I can get high speed internet services. It's a pain, but better than having the issues that come with slow internet. .
Dec 28, 2010 | Acer (4432A-002) CD-RW Burner
Hey I jus bought an used acer aspire 5220g when I switched it on it was workin fine, I un-iinstalled a program called rocket. Then I switch the laptop off. Few hours late when I switched it on, everything...
It seems that some critical windows system files have got corrupted and the 'rocket' seems to be an add on used to change the windows interface to look like vista or windows 7. The only way to recover will be to use the original OS CD/DVD to boot up your computer and use the repair &/or reinstall option. This leaves all programs & data intact, i.e. as it was, but just replace the original system files.
Nov 11, 2010 | Acer Aspire 5520-5908 Notebook
My Acer Aspire 5100 laptop won't boot. At startup the Acer logo is shown and than drops to a black window with flickering cursor (with now and than a loud bleep). Can anybody tell me what the problem is...
be sure to remove all other external devices hooked to your pc. just leave ac adapter plugged in. then try if it will boot to safemode by pressing F8 upon seeing the Acer Logo. if it will boot, what you need is reinstall your OS. if it will still not boot then you need to replace hdd.
Apr 08, 2010 | Acer Aspire 5100 Notebook
Cannot format c:
if you want to format it you have to reinstall the os . Actually all information of the os is sitting in c drive ... in running time of windows you can't format the c drive .....
To format and reinstall the os get a windows(XP,vista,98) botable cd ...boot from cd ... it will start the setup...... in middle of setup it will ask for the format ......
Nov 16, 2009 | Acer Aspire T650 (AST650UC3601) PC Desktop
My acer travelmate wont boot just beeps 4 times i recently reinstalled XP Pro os on acer ferrari 4000 and have recieved this same problem 4 beeps and black screen.won't boot..bios or os. HELP
I long + 3 short beeps or 3 short + 1 long beeps indicates memory problem.
The RAM module/s may need reseating to re-establish proper electrical contact.
If it still doesn't boot up then :-
Get the RAM module/s may be faulty, test the module/s in another laptop or get your friendly computer shop to test them.
May 07, 2009 | Acer Ferrari 4000 Laptop Notebook
Computers & Internet Logo
302 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
