Question about Kenmore Refrigerators
Fresh food compartment is not cold - Kenmore Refrigerators
  • appliance323 May 11, 2010
    need more info, what brand,style,age,etc
    President:
  • 1,218 Answers
Good day,
Not as much info as I would like, but here's a good list to get started with.
Note: Assuming the freezer is at or near normal.
1. Lights do not go out when door is closed. Can be tested by checking just before door closes completely.
2. Air circulation fan motor in freezer compartment, not running.
Can be heard when opening freezer door when machine is running.
Remove rear panel in freezer compartment, and repair or replace as necessary.
3. Most common. Defrost system failed.
The Auto defrost system is made up of three components.
1. Main heater, located behind the rear panel in the freezer compartment. 2. The defrost thermostat (often called a terminator) located on top of the evaporator coil which is located in the same area as in #1. 3. Defrost timer (either mechanical) or electronic) located in the fresh food compartment. This device initiates the defrost cycle once to twice a day.
Go to....
http://www.appliancepartspros.com with the complete model number of your machine to identify the location and style of your components.
Posted on Nov 17, 2009
Wont let cold air blow into the refridgetor side
If it isn't due to the fridge contents obstructing the cold air outlet in the fresh food compartment, it's probably an issue with the thermostat in the fresh food compartment or the fan(s) in the freezer compartment.
It may also be the first indication of a failed part in the defrost circuit. If the freezer compartment begins to warm over the next day or so, there may be an issue with the defrost timer, defrost terminator, or heater. Before digging around there tho, make sure the cold air openings in the fresh food compartment are not blocked.
If the fan(s) in the freezer have failed, they won't be able to blow the cold air into the fresh food area. If the thermostat failed, it will never be able to send power to the fan to cool the fresh food compartment.
Depending on your capabilities, this may or may not be a good DIY type job. Sometimes, a warm fridge / freezer is due to a refrigerant leak, and will require a licensed refrigerant tech to make repairs. Working in the tight confines of a fridge can be difficult - especially when testing components with power on.
I hope this helps - good luck!
Oct 21, 2010 | Refrigerators
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Maytag bottom freezer Model MBF2254HEB not blowing cold air into freezer or fridge, blows warm air if blowing at all, starts and stops. Any suggestions? Possibly a reset button somewhere? Thanks - Kurt
Aug 29, 2009 | Refrigerators
Fridg is not working right
Aug 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Have Sub zero side by side 561 Why does the temperature control not increase the cooling of the refrigerator? The milk and vegetables are spoiling.
Aug 28, 2009 | Refrigerators
Working fridge, warm freezer.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge doesnt stay cold
Aug 28, 2009 | Maytag MZD2766GES Side by Side...
Left door open while cleaning out refrigerator and top unit shut off freezer is still on what should I do
Aug 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fresh food compartment not cold, light is lit when door closed
Engwah, is this the correct model number or does it start with PSS. The light should do just the opposite, off when the door is closed and on when the door is open. This could be part of the non cool problem. If this model has the mother board wich controls the refrigerator it is very possible that the defective fan motor has damaged the motherboard. This is very common in GE refrigerators. The technician will have to run some tests on the board to eliminate it...Catriver..post back.
Oct 28, 2006 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
