Question about JVC AV-32230 32" TV
We have a black box on the tv screen. sound works and we can still watch vhs and dvd.
  • 405 Answers
Make sure that closed captioning/teletext is turned off.
Posted on Nov 17, 2009
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Daewoo dvd install
  1. Be sure that your VCR is a newer one with at least one "line in" set of jacks in the back. Some have one in the back and one in front.
  2. Your DVD Player should have a video/sound cable with 3 connectors on each end. Otherwise get one or 3 single cables.
  3. Connect DVD Video Out to VHS Video In (yellow).
  4. Connect DVD Left to VHS Left (white).
  5. Connect DVD Right to VHS Right (red).
  6. Turn on your DVD and VHS.
  7. Your VHS should have a tuner setting for "L1" or "L2". Select whichever shows the DVD's video on the TV.
  8. Remember to select that input channel whenever you want to watch the DVD.
  9. When watching a DVD, if you have a blank VHS in the VCR, you may record what you are watching onto the VHS, just as if you were recording from cable.
Verify these steps and you should be good to go ;)
Apr 19, 2008 | Daewoo DVDS151 DVD Player
Magnavox PIP, Insight Cable box, Sony DVD/VHS
1st conect cable, then 2. VHS , Then 3 dvd to tv.
Then you can record Cable wile watching a DVD
Nov 07, 2007 | Philips Magnavox 9P6034C 60" Rear...
JVC AV-32230 32" TV Logo
102 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
