Question about Dirt Devil Vacuums
Hi, my name is Nicole. I have a dirt devil d1. I have been having problems with the empty space that surrounds the air director. It is filling up and I'm having to unscrew it to empty it out. I have already checked the air director, and it is not clogged or anything. When I vacuum, the bottom part of the canister fills up, but so does this space at the top. Can you help?
  • 126 Answers
SOURCE: Dirt Devil Repair
Any warranty dealer for Dirt Devil should be able to supply a schematic for that machine. They have access to the dealer web site and can download the information.
Posted on Feb 02, 2008
reddevil6
  • 1673 Answers
SOURCE: I have a Dirt Devil
Some of the Dirt Devils have a reset button on the back, near the bottom. But if the it is getting hot on the bottom, that may mean the motor is trying to run but can't. Maybe something has jammed it. You would have to disasemble it to find out.
Posted on Mar 06, 2008
Agent Don
  • 310 Answers
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
SOURCE: DIRT DEVIL CLOGGING IN THE HOSE
What is the solution to this problem ?
Posted on Sep 19, 2008
SOURCE: dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Posted on Jan 16, 2009
Do my Dirt Devil have a restart button it just stop running
Hi! No the vacuum doesn't have a restart button, but it does have a thermal protector that will shut the vacuum down when it is overheated. If your dirt cup was too full this will activate the thermal protector sensor. Clogs and dirty filters can cause this as well. We recommend emptying the dirt cup, tapping out the filter and checking the hose for clogs. The vacuum will come back on usually within 45 minutes to an hour. Hope this helps. If you need further assistance don't hesitate to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil
Sep 20, 2014 | Dirt Devil Featherlite Bagless Vacuum...
I have plugged in my dirt devil and it wont turn on. other things are plugged into the same plug in and they are working. is there a reset button on the vacuum?
Hello! The Easy Lite does not have a reset button. It does have a thermal protector that will automatically shut the vacuum down if it is overheated. This is usually caused by either a clog or a dirty filter or a combination of the two. Try these trouble shooting steps below.
1. Remove the hose completely from the vacuum from both ends.
2. Use a broom stick or something similar to gently loosen and remove any clogs from the hose.
3. Remove the dirt cup. Remove the red air director by turning 1/4 turn counter clockwise. Remove any hair or debris from the air director.
4. Remove the filter from vacuum base. Hold filter under running water to rinse. Allow 24 hours to air dry.
When the thermal protector is activated the vacuum must cool down before it will power back on. This can take up to an hour. Hope this helps! If you still have questions feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Jun 03, 2014 | Dirt Devil Easy Lite Quick Vacuum
I cleaned my filter and forgot how to put it back on, how?
Hi there! To return the air director back into the dirt cup, rotate 1/4 turn clockwise to lock into place. To replace the pleated filter. Return filter cartridge to base of cleaner. Click button on filter cover back into place to lock filter cartridge in base of cleaner. Hope this helps! I have also included a link to the instruction manual for reference if needed. Thanks! http://dirtdevil.com/file/956/
May 20, 2014 | Dirt Devil Easy Lite Quick Vacuum
I have a dirt devil easy lite... how do I empty the top canister? I know how to empty the bottom half.
The upper half is where the filter is.
Here is the manual:
http://dirtdevil.com/file/172/
Page 7 shows after emptying the lower container, "Twist and lift to remove dirt container lid."
Aug 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    I HAVE A DIRT DEVIL SPOT SCRUBBER & HAVE NO USER MANUAL & NEVER USED BEFORE. CAN NOT FIND INSTRUCTIONS ONLINE. CAN ANYONE PLEASE TELL ME HOW TO FILL THIS MACHINE & USE PROPERLY? THANKS!
    Hi ramond745...
    Go to the following webpage and view the operating instructions for your Dirt Devil Spot Scrubber, you can also print the page/s on your printer for later reference.
    Please take time to rate me
    http://www.ehow.com/how_7830177_operating-dirt-devil-spot-scrubber.html
    Aug 16, 2011 | Vacuums
    Vacuum won't pick up
    Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
    Bissell Bagless Upright Vacuum not working
    http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
    heatman101
    May 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
    Our dirt devil vacuum is blowing out air instead of pulling in air.
    my dirt devil is blowing out air instead of sucking up.Tried new bag.any other solution to fix
    Aug 29, 2009 | Dirt Devil 12 Amp HEPA Filter Vacuum...
    I have a dirtdevil vaccum cleaner, model110008 mfg. code g07a I need a replacement part Air Directors. where can I buy these parts and how much.
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=725217
    Generic problem for all Vacuums
    I have a dirt devil vacuum
    Posted by busylady5555 on Jun 30, 2008
    I have a dirt devil vacuum cleaner, model110008 mfg. code g07a I need a replacement part Air Directors. Where can I buy these parts and how much?
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best place to get genuine Royal vacuum cleaner parts id to contact the Royal cust serv and they will connect you with the parts dept to order the part(s) that you need, or you can check with your local vacuum cleaner dealer in your area and they might have it in stock or they can order it for you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    Go Ahead. Use Us.
    Jun 30, 2008 | Vacuums
    Vacuums Logo
    103 people viewed this question
    Top Dirt Devil Vacuums Experts
    Jim Parker
    Jim Parker
    Tim Venetis
    Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
