Six year old Whirlpool 3357978 washer stops spinning violently
Six year old Whirlpool 3357978 washer stops spinning so forcefully that it makes a loud bang and shifts position. I believe the fault lies with the break. But I don't know why after six years it would start (you'd think it would get weaker), or how to fix it. Can you assist?
  • 95 Answers
The bowden cable requires adjusting like the brakes on a push bike
Posted on Nov 18, 2009
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Six year old Whilpool Duet washer on pedestal and level front and back still vibrates excessively and makes loud noise when spinning water out of machine. Is sitting on concrete floor. Have owned since new...
check the inner struts on the bottom of the tub you need to remove the front panel some have a split lower section so you can access inside where the struts are also check that the struts are not worn out hope this helps
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I own a whirlpool top loading washer - under 2 years old. it stopped draining water and spinning. replaced the timer and now it works fine, but now when the washer finishes spinning, the agitator stops...
depending on your exact mode;
sounds like a brake, or a clutch
those are really only two parts it could be
on the whirlpool the brake is part of the transmission on the direct drive
Oct 15, 2009 | Washing Machines
During the spin cycle, the machine shakes violently and dances across the floor. It has a loud squealing noise during this. My Performa is only about 14 months old. This is very disappointing for a Maytag.
Look in owners manual. I think these washers have a 1/2 hp. variable speed motor. make sure the washer is level from front to back and side to side, if its not that could be the problem. The motor has a lot of force, the squealing could be a bad bearing not sure.
Aug 24, 2009 | Washing Machines
Washer doesn't spin, just makes funny noise.
i would change the coupler between the motor and transmission.... whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool Washing Machines
I have a whirlpool duet washer that is making very
It sounds like basket support failure. How old is the machine? They usually **** at around 5 to 6 years. Unless you are going to fix it yourself or it's under extended warranty, junk it.
The repair requires a complete teardown of the washer. two to six hours labor depending on tech skill level.
Jun 12, 2009 | Whirlpool GHW9200L Front Load Washer
Violent and loud spin cycle Whirlpool Ultimate Care II
You may have one suspension point that has failed.
Open the back and using a flashlight, inspect the outer shell; the suspension should look the same at each point.
Don't know your particular machine but the suspensions are pretty primitive, some no more than heavy rubber rings at each point.
You're right that it shouldn't be ignored, as it can cause more problems and stresses the bearings abnormally.
Sometimes, this can be caused by running one very unbalanced load and not stopping the machine to redistribute the clothing to correct the imbalance.
This can cause a suspension point to become unhinged.
Aug 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud Noise at the End of the Spin Cycle
some item has fallen down between the outer and inner wash tubs? remove it
May 20, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
884 people viewed this question
Top Washing Machines Experts
