Question about Sony Video Game Consoles & Games
How do i connect my ps3 to the internet via wireless connection
    Novelist:
  • 132 Answers
Please find below:
  1. On the XMB™ home menu, go to how do i connect my ps3 to the internet - icn_settings.gif(Settings) > icn_networksettings.gif(Network Settings)how do i connect my ps3 to the internet - icn_btnx_color.gifg src="http://i.fixya.net/uploads/images/icn_btnx_color.gif" alt="icn_btnx_color.gif" class="h_mi" />button. how do i connect my ps3 to the internet - icn_settingitem.gif/>
  2. Then go to icn_settingitem.gif(Internet Cohow do i connect my ps3 to the internet - icn_settingitem.gift [Enabled].
  3. Then scroll down to icn_settingitem.gif(Internet Connection Settings) and press the icn_btnx_color.gifbutton.
    Selhow do i connect my ps3 to the internet - icn_btnx_color.gifonfirmation screen is displayed stating that you will be disconnected from the Internet.
  4. Select [Custom] and phow do i connect my ps3 to the internet - icn_btnx_color.gif"http://i.fixya.net/uploads/images/icn_btnx_color.gif" alt="icn_btnx_color.gif" class="h_mi" />button.
  5. Select [Wireless] as your connection method and press the button.
  6. Select the WLAN Setting.
    Choose how you wish to connect the Internet. For most users, "Scan" will be the option to choose.
    wirelesscustom06.gif //
    • Scan - This will scan for any wireless access points in the area. Choose this option if you are not sure of the name of your wireless access point (SSID).
    • Enter Manually - Choose this option if you know the name of your wireless network (SSID) and/or your SSID does not appear if you chose the "Scan" option.
      You will need to contact the persohow do i connect my ps3 to the internet - icn_btnx_color.gifntains your network to obtain this information.
    • Automatic - Choose this option only if your wireless access point supports automatic configuration (i.e., AOSS).
      Select how do i connect my ps3 to the internet - wirelesscustom07.gif that you want to use and press the icn_btnx_color.gifbutton.
    The security setting varies depending on the access point. Contact the person who maintains the access point for information on which setting to select.
    wirelesscustom07.gif //
  7. If you selected a Security Setting, enter your security key whow do i connect my ps3 to the internet - wirelesscustom08.gifbr /> Press the [Start] button to exit the onscreen keyboard.
    Press right on the directional pad to proceed to the next screen.
    The encryption key is displayed as a series of eight [*] no matter how long the key may be. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
    wirelesscustom08.gif //
  8. On the IP Address Settings screen, you will need to select one of the following three "Custom" options: Automatic, Manual or PPPoE.
    PPPoE is usually used for DSL broadband connections that require you to enter a user ID and password. You would normally only use this connection type if you have a wireless access point without a router. It should only be used if you are connecting directly to your ISP without using a home gateway router OR using a router that does not authenticate your PPPoE connection for you.
    To use PPPoE settings:
    • On the [IP Address Settings] screen, select [PPPoE] and press the right directional button.
    • You will be asked for your PPPoE user name (or user ID) and password. You will need to get this from your ISP.
      Note : When entering user names and passwords, keep in mind that User Names and Passwords are often case sensitive, so make sure that you enter them EXACTLY the same as they were created, including the same UPPER and lowercase letters, where appropriate.
    • Check your settings to make sure that they are correct.
  9. Once complete, a list of settings will appear. Make sure all settings are correct and then press icn_btnx_color.gifbutton to save the settings.
  10. Press the icn_btnx_color.gifbutton to test the connection.
  11. When the test is complete (usually less than a minute), it will display the results ("Succeeded" or "Failed"). If you have successfully connected to your network, congratulations, you have completed the network setup process.
Hope it helped.
Posted on Nov 18, 2009
I am tryn to sign in,through the PS3 onto my internet. how do I get connectivity?
If you are trying to connect via a wired connection you should be able to just plug in an ethernet cable from your router/modem straight to the PS3 and it should connect.
If you are trying to connect to the internet via the PS3's built in wireless capabilities head under network settings via the XMB and scan for nearby wireless connections. Once it has found yours select it and enter your password if needed.
Mar 14, 2011 | Video Game Consoles & Games
Connecting via Wireless router
I assume you want to simply connect wirelessly to the internet with your PS3. Its very simple, just go to Network Settings, select wireless connection and then "Easy" setup. The only thing you should need is your wireless encryption key which would of been supplied with your router.
Hope this helps.
Jul 28, 2010 | Sony Playstation 3 (PS3) Console
Hello, Can you tell me how I set up my internet wireless connection please. I have tried using the step by step guide in the manual but without success. When It asks you to enter the wep code it tell me no...
are you putting in the password for the wireless internet
make sure that the password that you enter in the ps3 internet settings is the same password for the wireless router
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
Using a notebook PC's internet signal to go online with a PS3
you could connect your laptop to the internet and then connect your ps3 to your laptop either via wireless or cross over cat 5 then make a bridge between your internet connection and which ever connection you conected your ps3 to.
Sep 10, 2009 | Dell Inspiron 1521 Notebook
Cannot connect via wireless network, router not being detected by laptop or ps3. I can connect to internet on desktop via modem through router. When trying to detect wireless network via laptop and ps3...
stupid question : is Wifi turned on ?
Go to your administration environment of your router ( typically : http://192.168.1.1 ) and check the config of the wireless settings
Aug 14, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Ive got verizon wireless broadband for my lap top and cant seem to be able to get online with ps3
Can you provide more information?  The Verizon Wireless broadband access is for your laptop only.  In order for the PS3 to take advantage of it, you'll have to setup Internet Connection Sharing on your laptop. That way your PS3 can connect to your laptop via your laptop's wireless connection (in Ad Hoc mode since you don't have a wifi network) and access the internet via the VzW Broadband Access.
Dec 25, 2008 | Sony Playstation 3 (PS3) Console
How can i get my 60 gig ps3 to go online with wireless connection
the only way you can connect a PS3 to the internet is either though an Ethernet cable what comes out of your router
Or By Wireless
Dec 17, 2008 | Sony PlayStation® 3 (60 GB) Console
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
Video Game Consoles & Games Logo
128 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
