Question about Vacuums
White screen on start up & also small box called project 1 with run time error '75' path/file access error
  • mike_brenett Nov 18, 2009
    The Laptop is an ACER Aspire 5810T.....
  • ChrisScott May 11, 2010
    is this an acer laptop..?? a make and model number would help..? sound like the Hard-drive may not be connected
  • 51 Answers
The best solution for you its to load fresh OS XP or Vista.
Posted on Nov 17, 2009
Where is the reset button on the Bissell Powerforce helix upright ?
This unit does not have a reset button or fuse that is accessible or repairable. If you are referring to the manuals troubleshooting no power, the blown fuse or tripped breaker that is being referred to in the manual is your house hold breaker box and the fuse or breaker that handles the outlet the unit is using.
If your having power issues you should first inspect that all accessible parts are functioning. Such as hoses being closed, dials resting in the set positions, wand locking. Also if visible the sensors that are keeping tabs on each part. Another issue may be that the cord had been kinked and has shorted out, one possible way to check this issue is: if the unit powers up only when the cord rests in certain positions.
If this was recently purchased the warranty is for one year. A ship repair cab run $35 to $100+ you will have to call around. Or have a handy family member you with it.
Being these machines can be found $50 to $75 a replacement would probably be your best bet.
e72fb1da-2558-49cd-81a9-99825035337b.png e48073ba-4f6c-40a2-92a7-244dedbcfce5.png
Aug 03, 2014 | Bissell 6594 PowerForce Bagless Upright...
Kenmore canister - trips 15 amp circuit breaker
Check specs on unit and amperage. If it is less than 15 then the upstairs breaker is kicking off prematurely - Not uncommon event. If unit is drawing more power than specs there is excessive friction in motor bearings. Also check out brushes for good contact since they wear.
Sep 11, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
My Tork 1101 24 hr timer has stopped working. I hear it running, but the clock will not turn. I have to turn it on and off manually for my pool pump. This happened 2 years ago, then the following year...
You might need $45 clock motor for for Tork 1101 120Volt.
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Open following link to identify timer and see replacement clock motor and trippers:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Intermatic crossover shows T101 timer replaces 120Volt Tork 1101.
Amazon sells new Intermatic timer for $45 with super shipping
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
Crossover wiring from Tork to Intermatic:
Black wire on Tork L and 1 connect to Intermatic terminal 1
White wires on Tork X connect to Intermatic terminal A
Black wire on Tork 2 connects to Intermatic terminal 2
http://waterheatertimer.org/How-to-wire-T104-Intermatuic-timer.html#T101
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 04, 2011 | Vacuums
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
New vaccuum will not recline
This is what worked for us. On the DC28 There is a small channel directly down the center of the vacuum & hard to get to between 1/2 & 3/4 inch in width (See red arrow on image). A plastic latch is far up inside (even beyond the yellow arrow on image). You'll need to use a small flat screwdriver to disengage the latch. I then used white lithium grease & it freed up the mechanism to work smoothly._500.jpg
Dec 24, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
We have a zenith dehumidifier model ZD300 & the bucket full light keeps flashing. the percentage number wont go higher than 1%. we have turned it off/on & unplugged it. When we do this it will...
I've had the same issue with mine. I am a 12 year refrigeration tech. I checked the float switch which would normally cause that indication light. However manually pushing the switch and then checking it with an electric meter that was not the case. I think that is instead, an error code set by the manufacturer to assist the service tech when or if this failure occurs during the warrenty period. I also checked the next possible failure in the sequence of opperation which would be the compressor overload relay. That is sometimes why, as some people have posted, that after when unplugging the unit, it operates for a short time then again fails. In my case that was the failure. If that would have not been it than I would have tried the compressor start relay. I purchased the overload relay from my local HVAC/plumbing supply for around 7$. The control can easily be replaced by any handy homeowner. Also, as a service tech, 7$ and two wire nuts is better than a 145+$ service call.
Nov 28, 2010 | Vacuums
My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Need switch for a shop vac modle qpl650
Ok - heres my story - QPL650 crapped out mid job, checked this post, ordered the switch on the link here, didn't work.
Called Shop Vac, priced a power unit assembley ($82), took the motor apart and traced the orange wires into small junction box, replaced the little rod connecting the contacts with a 1/2" of coat hanger (white paint scaped off first) and I am back in business.
Now I am thinking $82 invested in an index fund at 6% per annum for 20 years is...................
Dec 12, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
