Question about Whirlpool LSN1000LW Top Load Washer
Bolt in agitator came out
How do you put it back in and what tools will I need?
    Master:
  • 619 Answers
Open back cover /look where the bolt are suppose to put it back / use flush light / incline it so that you may able to see below /you may use socket wrench or back wrench depends how size is the bolt.
Posted on Jan 10, 2008
Agitator came off along with bolt
about an inch ushould be able to screw the bolt back in its usually a 7/16 bolt and nut
Jun 06, 2015 | Washing Machines
Our agitator on the Simpson esprit450, keeps slowly coming loose after we tighten the bolt using an extension, does it need a washer under the bolt or a new agitator ????
Hi just read your posting.1st thing to do is to undo the screw holding the agitator to the shaft and lift the agitator out.Then purchase some Loctite thread lock from you local hardware store.Put some thread lock on the thread of the bolt and re screw the agitator back in place.Leave the machine for 24 hours and this will fix you problem.I use this method when I am repairing machines for customers.Please reply if you need further help and also to let me know how you got on.Good luck and hear from you soon.
May 14, 2011 | Washing Machines
Hello. We have a Whirlpool Ultimate Care Heavy
yes you r. lol
the agit. dogs need replaced look in your phone book 4 a dealer near you to get this part you need. remove softner despenser and inner cap then you will need to remove bolt 7/16th or 3/8th after removing bolt pull up on agit.it is 2 pc if it all comes out as one pc. ok you need to stand on lower 1/2 and pull up you now have the top pc in your hands. you will see some type of cup that holds in the dogs remove by flipping up side down install new parts and put back togther a small tip use the bolt
to put cup back in when you are ready to put back together put top pc of agit. over cup up side down you will need to line up with 2 or 4 ears on bottom pc. it should click now reinstalle sound hard but very easy just keep preassur on dog cup at all time with bolt and socket have fun
Feb 10, 2010 | Whirlpool Washing Machines
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
Top agitator not working properly
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Agitator dogs part number is 80040
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Directios for changing agitator dogs
take the cam out take the yellow bushing off, put new dogs in, put yellow bushing back on, put agitator back into washer, put cam back in with dogs inside it, facing down, put bolt back in and cap. new dogs usuaully come with instructions.
Feb 10, 2009 | Whirlpool Washing Machines
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Jul 10, 2008 | Maytag PAV2300 Top Load Washer
GE washer WWSR3090T6WW
I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
Oct 22, 2007 | GE WDSR2080D Top Load Washer
Whirlpool LSN1000LW Top Load Washer Logo
37 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
