Question about Cell Phones
NEED TO MAKE A LINE RING ON A EXTENSION INSTEAD OF RECEPTIONIST..HOW CAN I MAKE THIS HAPPEN?
We have 4 RCA 25425 phones in our office. When someone calls, all phones ring. We only want main line to ring.
Page 15 of the manual shows how to turn individual phone ringers off using the "Ringer tone" setting option. RCA 25425RE1 User Manual Page 15 Hope this helps
Jan 10, 2014 | RCA 25425 / 25425RE1 4 Line Corded...
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Everytime that anyone calls the receptionist, her line is busy, How do I correct this issue? Thank you . Panasonic KX-T7630
A couple of ideas. Have the receptionist call you and verify that they are really at the extension you're calling. Then make sure you turn on Call Waiting Intercom on that phone. From the intercom on the reception phone, dial *7311 for Intercom and *7321 for Outside lines.
Now the phone will soft ring and visual indication when you get a second call if you're phone is busy.
If you've mapped a button to ring the receptionist and it's not working, you may have unprogrammed the button. That's reprogrammed by PROGRAM, the button and 1 plus the extrension (usually 101) and STORE or ENTER to save. PROGRAM exits programming.
Carl
Jul 22, 2010 | Panasonic KX-T7630 Corded Phone
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
M7310 phone line ringing does not appear on receptionist phone
Feature **266344
Password 266344
Terminal & Sets
Press Show (Top Right Button)
It will Ask Extension Number
Change to Appearance & Ring
Sep 29, 2009 | NorStar M7310 Corded Phone
I want only the receptionist phone to ring
To change ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear and ring press CHNG til it says appear only.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Sep 14, 2009 | Nortel T7316E 2-Line Corded Phone
Auto attendant does not pick
What kind of phone system? If Partner, it sounds alot like you lost all your programming, so the phone system isnt programmed to know where the voicemail is. So hwen a call comes in, the ports where the voicemail is, ring, so they pick up, but dont know what they are to do with the call, so they shove it to the receptionist.
#505 needs to be programmed, then #206, that will get you to at least asnwer incoming calls.
Need to know more, like WHAT KIND OF SYSTEM.
May 27, 2009 | Avaya AT&T Partner Phone
Multi line system and phone still rings while I'm on another line
courtney,
Unfortunately if the receptionist is using priority call (f69) there's not much you can do. Priority call is an administrator programmed function that overrides when your on a call and when the set is in do not disturb. Maybe bribing the receptionist might be in order.
Feb 12, 2009 | NorStar Meridian M7310 Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
