Question about Maytag MGR6775 Stainless Steel Kitchen Range
My top oven will not heat up...Maytag MGR6775... Anyone know where to start?
  • 491 Answers
IT SOUNDS LIKE THE ELEMENT HAS BURNT OUT ,TO FIX THIS FIRST TURN OFF THE POWER TO THE COOKER , THEN LOCATE THE SCREWS ISIDE THE OVENS BACK PANEL REMOVE AND TAKE OFF PANEL YOU SHOULD SEE THE ELEMENT REMOVE IT FROM THE CONECTOR BY PULLING IT OUT BUT FIRST UNCLIP IT , THEN BRING THE ELEMENT TO AN ELECTIRCAL AND PLUMMERS SUPLY STORE FOR NEW REPLACEMENT THEN FIT NEW ELEMENT AND YOUR OVEN SHOULD BE LIKE NEW, GOOD HUNTING.
Posted on Nov 17, 2009
Mgr6775 ovens not functional
Could you describe your problem a little bit better?
Mar 02, 2014 | Maytag MGR6775 Stainless Steel Kitchen...
Maytag MGR6775 Ignitor is NOT problem but upper oven inop
Ignitor might be weak but appears to still work. Replace it anyway
Feb 21, 2013 | Maytag MGR6775BD Gas Kitchen Range
Maytag gemini mgr6775 oven light turns off and on
This is a not an uncommon issue. Replacing the control board. It solved the light & clicking issue. Check online for parts try ereplacement or http://www.appliancepartspros.com/
Jan 24, 2018 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag Gemini mgr6775 Lower oven takes FOREVER to preheat, but even when it says it is at 350, an independent oven thermometer says 310. It takes so long to bake anything.
Dear Scrapyourhea,
First ensure that your independent thermometer is working fine. It seems that there is problem with your heat mechanism. Normally this type of problems requires servicing....
Download the manual from given link and go through it. This will tell you the cause for the same.
http://www.retrevo.com/support/Maytag-MGR6751BDS-Ranges-manual/id/23649ci773/t/2/
Jun 07, 2010 | Ovens
Upper oven makes loud whooshing noise sometimes , like the gas ( propane )is blasting full tilt model mgr6775 ,mgr6875
The gas is not the problem... the ignitor is...
The gas is building up in there before it ignites because the ignitor is not working properly...
Replace the igniotr and the problem will go away..
Check out this tip...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 11, 2010 | Maytag MGR6775 Stainless Steel Kitchen...
OVENS DONT WORK
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Dec 05, 2009 | Maytag MGR6775 Stainless Steel Kitchen...
Oven heats very slowly
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Jan 04, 2009 | Maytag MGR6775 Stainless Steel Kitchen...
Oven Problem
Yes, I replaced the lower oven sensor: it did not have continuity once disconnected from the rest of the circuit. That sensor transfers the power to the lower bake ignitor.
Nov 05, 2008 | Maytag MGR6775 Stainless Steel Kitchen...
Open Questions:
Maytag MGR6775 Stainless Steel Kitchen Range Logo
258 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
