Question about NetGear DG824M Wireless ADSL Modem Gateway Router
Netgear DG824m Disconnecting every few mintes
Hi, recently my connection to the net has started to disconnect after a few minutes and then reconnect itself again, this happens all the the time. Firsti was thinking my ISP maybe but did a bit of searching on the net and found others had the same problem. I have got the latest software upgrade as far as i know Ver 1.4 Release 05. Any help would be great, Thanks Tony Pickard
  • tpickard Nov 18, 2009
    Thx Geekman but maybe i should have said that it's not the wireless side of connection i am loosing, its the hardline into the back of the PC. I have secured the wireless from others, altered password, 128 encrypt etc. Maybe the router is just getting old, maybe upgrade to the newer 834 model or another make al togeather...
    Hi Geekman, maybe i should have made it a bit more clearer, it's not the wireless side i am worried about, its the hardwire into my main PC that keeps dropping the connection. I have done most of the stuff you said for the wireless anyways but am struggling to fix main PC issue. Maybe purchase the DG834 newer model as mine is about 5 years ols now i recon, unless i get this sorted...thanks.
  • NetGear Master
  • 32,281 Answers
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Nov 17, 2009
  • Chris Hingee
    Chris Hingee Nov 18, 2009
    Sounds like you have a flaky LAN card.
Expant Shield does not connect anymore. One day it worked fine and since about a week it does not connect anymore. No changes to location, computer, internet connection, etc. Possible that my ISP (I live...
That is a typical problem/issue. What happens is the ip block gets blacklisted and no longer works. All you need to do is wait a few days and it should work again. I think the longest I've seen it down lately is about 4 days or so. Hotspot is pretty proactive on fixing the connections so it usually is much faster. There are a few things you can try such as disconnecting, wait a minute and then reconnect to get a different ip. If the ip is out of the blacklisted range you should be able to watch the BBC/IT4 etc again right away. If not then about all you can do is wait and keep trying to connect. The disconnects I've seen recently are very short compared to when they first started. Those lasted weeks sometimes.
Oct 15, 2011 | AnchorFree Expat Shield
I recently bought Belkin F7D1401 V1 Adsl 2+ router, it keeps disconnecting after every few minutes and reconnecting on its own, please help
This type of problem can be caused by several interference problems. Please click on this link and follow my instruction to determine the cause and fix :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Jan 07, 2011 | Belkin (F5D7230-4) Router (587009)
Pandigital novel ereader is not connecting to Netgear router and home wireless network
try resetting the router by disconnecting the power to it for a few minutes
Dec 29, 2010 | NetGear Computers & Internet
My wg111t connects for a few seconds then disconnects. I can get online but it is constantly connecting then disconnecting the connecting and so on its pissing me off help!!!!!!!!!
please increase channel number on router,it will fix your
recomended channel number is 11 or 09 for netgear adapter
and also you can upgrade driver for adapter
regards
prakash
Jan 19, 2010 | NetGear WG111T 802.11g/b (E82321) Wireless...
The unit turns on then shuts off after a few seconds.
This could be a bad speaker or speaker wire. I had this same problem recently. In my case it was the powered sub-woofer. I disconnected the speaker wire from the back of the receiver(with the power off, of course). When I powered up the receiver, problem solved, it worked fine. I then made sure the wire was not shorting out, carefully reconnected everything and the sub works too. I never found the cause, but it has worked fine for several months now.
You can start by disconnecting all the speakers. If the receiver powers-up reconnect them one at a time to find the bad wire/speaker. If it is not the speakers, disconnect all attached devices. If the receiver still won't power-up go shopping for a new one. It is not worth repairing. It is less expensive to replace it.
Remember, always turn the power off and set volume to zero before disconnecting or connecting anything! You don't want to cause any damage.
Nov 06, 2009 | Yamaha HTR-5790 Receiver
Telstra V580a cordless phone not working.
Try disconnecting all power to the base stations and the batteries in the handsets for a few minutes.After reconnecting power it may take a few minutes for the units to reconnect.
Good Luck
Doc
Aug 14, 2009 | Lands Phones
Internet is constantly disconneting and reconnecting
This is a firmware problem of your router, the firmware is the software of your router and its should be updated , just downlaod the latest firmware from Netear wen site and if you don't know who to update the firmware you can contact this number so a technician can walk you through and solving your problem and updating the firmware of the router 1-877-787-8749.........
Oct 18, 2008 | NetGear RangeMax WPN824 Wireless Router...
Netgear RandeMax 3500 and comcast problem
just double check in the router settings and see the connection speed (not internet ISP speed), it may be set at 108MBPS and your reciever may only be able to connect at 54MBPS.
Aug 17, 2008 | NetGear RangeMax WPN824 Router
Permanent Connect and disconnect with K750i
I had the same issue with my LG Vx8700 phone. Turned out to be the phone and not the parrot. Am on my third replacement Vx8700 and it is working fine for now.
Feb 04, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Webcam
hi,
there are a number of reason for what your webcam might get disconnected .
1. If your net connecting is very slow. the chat (mostly seen in yahoo ) gets disconnected and as a result the webcam too stops broadcasting.
2. If your net disconnects and reconnects.
3. if you have a lose connection of the web cam with the computer.
next time it happens check out if the net connetcion is ok.
hope it helps.
regards
bzoy
Jan 09, 2008 | Logitech Webcam
NetGear DG824M Wireless ADSL Modem Gateway Router Logo
238 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
