Back to:
Tags:
RCA L37WD12 37 in. HDTV LCD Television
Strobe light (by 2 users)
posted by Rhonda2654 on Jan 10, 2008
I got this tv 12/25/2006 as a xmas gift about 7 days ago the picture on the tv started acting like a strobe light effect, first couple of days it would stop after 15 minutes now it is non stop, it was hooked up to cable I removed the box and unplugged the tv as rca recommended and is still doing it any suggestions on what might be going on?
Rhonda
Comment by Rhonda2654, posted on Jan 10, 2008
rca l37wd124
Comment by Rhonda2654, posted on Mar 04, 2008
Here is what I found out it is the lcd screen I took it to the repair shop and on top of that it is not a part that is no longer made. So right now I am working with RCA to see what they will do
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jan 26, 2008
im having the same issue@ Any help would be appreciated.
Can you Help with these Flat Panel Televisions problems?
I have a RCA tv and dvd player combo. When i went to turn...
My TV comes on sometimes(most times) with either a grey...
I can't seem to get the right picutre qlty using the...
My works fine, but after 10 or 15 minutes using it, the...
we have unplugged it and replugged the tv only to find...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
