Question about Microsoft Windows Server Standard 2003 for PC
No operating system found on my 386 pc
Monator shows message, "no operating systemfound", but it was working fine until i shut off power switch.
  • 233 Answers
Make sure there is no Floppy disk in the drive if you have a floppy drive, if so the computer will try to boot from it. also check there is no USB drives or CD's in the drives
or your hard drives boot sector may be corrupt by a failing drive or virus damage, boot with windows CD and do a repair.
thanks for rating
Posted on Jan 10, 2008
Toshiba 351c is not working showing message reboot
If system is stuck, try to reboot the system by pressing power button and keeping it down until system shuts down (hold it down 5+ seconds).
May 23, 2014 | Toshiba Computers & Internet
Operating system not found
there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
Apr 10, 2013 | Samsung N150 Notebook
When i open the system the message shows myweb dll error i am using xp
restore your system to the date when your computer works fine just do this steps :
1 start
2 all programs
3 accessories
4 system tools
5 buck up
than choose buck up your computer than clic next choose the date when your computer works fine and clic finish
just wait until the job finish
that's all
Jun 06, 2010 | Microsoft Windows XP Professional for PC
Hai friends........ I am not able to shut down my PC
Ive seen this happen B4..
try holding the power button in..
If your useing the power button every time, it could be sticking,, Or you have it setup to restat when the power button is pushed.
If button is ok and power setting are set right then its *********** board
Dec 01, 2009 | Microsoft Windows XP Professional With...
Thanks for the response to my Acer L100. have checked the cables and they are fine. have noticed the fan doesn't start up when the computer is switched on....could this be the problem???
The CPU fan should turn on when the PC is powered on, and then it usually slows down until the workload on the processor causes it to heat up, then the fan spins faster, it might also be a power supply issue, but if your able to boot and its giving you messages and not shutting down then you should re-install the operating system.
Nov 18, 2009 | Acer Aspire L100 PC Desktop
When my pc starts up i get the message :Air GCFG .exe- entry point not found. Then I get a second error message saying Procedure entry point aspInitialize not found in the link library wlanapi.dll
did you update from sp2 to sp3 remove sp3 for one reason
fixed it by going to Windows Defender, Tools - Software Explorer and
disabled AirGCFG.exe from automatically starting at boot.** Now I don't get the error message and
the Dlink NIC card works just fine.
AirGCFG is a NIC monitoring function and the NIC will work without it.
Dlink was advised and reported back that SP3 was still Beta and they may work on the problem after
MS releases the final SP3.
I informed them that they did not know what was what and I would not hold my breath until they fix
the problem.
Found out the problem was due to a new version of the wlanapi.dll file introduced with SP3 that
conflicts with the Dlink monitoring file.
** Note: AirGCFG did not show up in the "msconfig" startup listing. But does show in Windows
Defender, with an explanation of what it does.
Jun 11, 2009 | Microsoft Windows XP Professional With...
Pc entering power saver mde
This message apears when there is no input coming from your computer. There should be a bution you can puch on the monater that would cnahge it from digatail to analog this may be the problem that you are having problems with
May 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Screen blank. only pointer shows
It sounds like damaged OS or registry. You need to restore the operating system. Try F8 at reboot and select "Safe Mode".
Nov 30, 2008 | Gateway MT6728 Notebook
Acer laptop aspire 4710z config my notebook have problem
There could be an issue with the user accounts logins. This could be corruption in the OS when you installed it or a clashing driver . I would recommend you reinstall the Operating System with the Disks and before you start installing the drivers try to shut down and see if it shuts down properly . If it does then you know the Operating system and hardware is all fine and can continue installing one driver at a time and shutdown and restarting, continue doing this until you see which driver is causing a confict with your system. I have had a problem similar to this but it was some windows updates pack that I had done one time and had to reinstall windows too and do one by one. Hope my answer gets you closer to a solution.
Aug 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Microsoft Windows Server Standard 2003 for PC Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
