Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
Insert Last Disk of Multi Volume Compressed File Signal - it always pops up when I put the disk in and won't go away- what can I do
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Jan 30, 2010
Can I open zip file in disk
How to Unzip and Zip files
cvs.bio.unc.edu/.../unzip.../un...
University of North Carolina at Chapel HillThis is very useful when disk space is limited or when people download files. Since multiple files can be stored in a zipped file, a single file can be downloaded ...
How to Open ZIP Files in Internet Explorer - For Dummies
www.dummies.com/how.../how-to-open-zip-files-in-internet-explorer.ht...
Sometimes when you download files from a website they arrive compacted into a form called ZIP. Compressed files download faster, so ZIP can be an ...
Zip File Spanning - WinZip Computing :: Knowledgebase
kb.winzip.com > KB Home > WinZip > Zipping and Unzipping
WinZipMar 11, 2015 - WinZip Pro will automatically create a Zip file that spans multiple discs if ... To unzip a spanned Zip file, first insert the last disc of the spanned ...
Multiple Disk Spanning - WinZip
kb.winzip.com/help/help_span.htm
WinZipTo make a Zip file that spans multiple disks, simply create a new Zip file on a ... Toextract files from a spanned Zip file, insert the last disk of the series and open ...
unzip - Python: downloading and unzipping a .zip file ...
Jan 27, 2016 | SanDisk 4GB Memory Stick Micro M2 Memory...
Tip
How to use file compration in winxp
How To Use File Compression In Windows Xp
How To Use File Compression in Windows XP
Article ID : 307987
Last Review : July 15, 2004
Revision : 1.1
This article was previously published under Q307987
IN THIS TASK
• SUMMARY
• NTFS Compression
• Compressing an NTFS Volume
• Compressing Files or Folders on NTFS Volume
• Displaying Compressed Files in Color
• REFERENCES
On this Page
SUMMARY SUMMARY
REFERENCES REFERENCES
SUMMARY
Compressing files, folders, and programs decreases their size and reduces the amount of space they use on your volumes or removable storage devices. Volume compression decreases the amount of space that is used by all of the files and folders that are stored on that volume. Because of a potential loss of performance, you may not want to compress some files.
back to the top
NTFS Compression
NTFS compression is available on volumes that use the NTFS file system, and NTFS compression has the following features and limitations:
• You can use NTFS compression to compress individual files and folders, as well as an entire NTFS volume.
• You can compress a folder without compressing its contents.
• You can work with NTFS-compressed files without decompressing them, because they are decompressed and recompressed without user intervention.
• You can display NTFS-compressed file and folder names in a different color to make them easier to identify.
• You may notice a decrease in performance when you work with NTFS-compressed files. When you open a compressed file, Windows automatically decompresses it for you, and when you close the file, Windows compresses it again. This process may decrease your computer performance.
• NTFS-compressed files and folders only remain compressed while they are stored on an NTFS Volume.
• You cannot encrypt an NTFS-compressed file.
You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure. To compressing an NTFS volume:
1. Click Start, then click My Computer.
2. Right-click the volume you want to compress, and then click Properties.
3. On the General tab, click to select the Compress Volume to save disk space check box, and then click OK.
4. In Confirm Attribute Changes, click the option you want.
To compress a file or folder:
1. Click Start, and then click My Computer.
2. Double-click the NTFS Volume that contains the folder or folders you want to compress.
3. Right-click the file or folder you want to compress, and then click Properties.
4. On the General tab, click Advanced.
5. Click to select the Compress contents to save disk space check box, and then click OK.
6. In the Properties dialog box, click OK.
7. In Confirm Attribute Changes, click the option you want.
NOTE: If you move or copy a file into a compressed folder, it is compressed automatically. If you move a file from a different NTFS Volume into a compressed folder, it is also compressed. However, if you move a file from the same NTFS Volume into a compressed folder, the file retains its original state, either compressed or uncompressed.
You can change the display of files and folders that are compressed in Windows Explorer and My Computer, so it is easy to see them. To display compressed files in color:
1. Double-click Folder Options in Control Panel.
2. Click Start, and then click Control Panel.
3. Click Appearance and Themes, and then click Folder Options.
4. On the View tab, click to select the Show encrypted or compressed NTFS files in color check box.
REFERENCES
Windows supports two types of compression, NTFS compression and compression by using the Compressed (zipped) Folders feature.
For additional information about zipped folders, click the article number below to view the article in the Microsoft Knowledge Base:
306531 How To Use Compressed (Zipped) Folders
For additional information about NTFS compression, click the article number below to view the article in the Microsoft Knowledge Base:
251186 Best Practices for NTFS Compression
on Sep 25, 2010 | Computers & Internet
Advent will not BOOT
The BOOT.INI file may be corrupt. Boot to a command prompt and rename original file c:\ren boot.ini boot.tmp. Now type edit. and insert the following script.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
Save as boot.ini. Alt key gives you the menu options
You can also create the file elsewhere and copy to c:\ Remember to rename original.
Note! This is a single partition standard from factory configuration.
Oct 25, 2012 | Computers & Internet
Memory card password forget ,please give key solution
Insert the MicroSD card into an available media reader slot on your PC. If your media reader can't read MicroSD cards, but can read ordinary SD cards, first insert the MicroSD card into an SD adapter, and then insert the adapter into the slot. You will see an autoplay menu for the disk pop up on the screen.
  • 2 Open the folders on the disk and navigate to the "System" folder. Click on the "Open folders to view files" option from the autoplay menu, then double-click on the folder that says "System." This is where your card's password file is stored.
  • 3 Open the password file. In the "System" folder, find the file that has MMCSTORE somewhere in its name. It may have additional letters, numbers and characters, but it will always have MMCSTORE in the title. Double-click on this file to open it in Notepad. The text inside this file is your lost MicroSD password.
  • Oct 31, 2011 | Cell Phones
    My micro sdhc is locked and asking me for the password which i cannot remember. can it be unlocked
    Insert the MicroSD card into an available media reader slot on your PC. If your media reader can't read MicroSD cards, but can read ordinary SD cards, first insert the MicroSD card into an SD adapter, and then insert the adapter into the slot. You will see an autoplay menu for the disk pop up on the screen.2 Open the folders on the disk and navigate to the "System" folder. Click on the "Open folders to view files" option from the autoplay menu, then double-click on the folder that says "System." This is where your card's password file is stored.3 Open the password file. In the "System" folder, find the file that has MMCSTORE somewhere in its name. It may have additional letters, numbers and characters, but it will always have MMCSTORE in the title. Double-click on this file to open it in Notepad. The text inside this file is your lost Micro SD password.
  • Sep 23, 2011 | Nokia E5 Cell Phone
    My LG GSA-H55L super multi DVD rewriter seems to suddenly have a problem recognising disc. I am using the same discs as before (same batch) but now it always tells me no disc.
    have you tried a cleaning disk?if not get some cleaning alchol wipe the disk leave a little on it not much,insert the disk ,this might clean the lense.
    Sep 11, 2009 | LG 20x8x20 GSA-H55L Super-Multi Disk...
    In my pc there is an problem of NTLDR missing . why this ill occure?
    1. Create a Windows 2000 boot disk that contains the following files: Ntldr
      Ntdetect.com
      Boot.ini
      Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
    2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
    3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
    4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
    Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
    1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
    2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
    3. Press C to repair the Windows 2000 installation by using the Recovery Console.
    4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
    5. Type the Administrator password, and then press ENTER.
    6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
    7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
      copy drive:\i386\ntdetect.com c:\ If you are prompted to overwrite the file, type y, and then press ENTER.
      NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
    8. Type the following command, and then press ENTER: type c:\Boot.ini A list similar to the following list appears: [boot loader]
      timeout=30
      default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
      [operating systems]
      multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
      If you receive the following message, the Boot.ini file may be missing or damaged:The system cannot find the file or directory specified.
    9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
      1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file:[boot loader]
        timeout=30
        [operating systems]
        For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
      2. Save the file to a floppy disk as Boot.ini.
        NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
      3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
    10. Type exit, and then press ENTER. The computer restarts.
    Dec 05, 2008 | Computers & Internet
    Computers
    most backup software can do this.
    If you have about an hour to wait, you can use the shareware version of winrar to create a multi-volume .rar compressed file. You can set the target file size (in this case 700mb) and it will split it up automatically.
    Note that when you restore the data in the future you would have to copy the data all into a single folder before restoring it.
    Another option you have is to buy an aftermarket backup/archiving program. nearly every one except the free one with windows will let you burn to cd/dvd.
    Aug 13, 2008 | Lite On SOHR-5238S CD-RW Burner
    Won't boot without a windows disk...
    Just taking a guess here. Did you do a fresh install of winXP? This type of problem is usually caused because the boot.ini is out of order OR your BIOS settings are not correct. Get into windows however you have to. Once in windows you'll find the boot.ini on the root of C:\ Please copy this file to a floppy disk just in case you make a boo-boo.
    You need to check this file. Double left click the file & it will open in notepade. There are five lines and they must read like below, do not make a single line turn into 6 lines.
    It should look just like this:
    [boot loader]
    timeout=30
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
    The only differance between you & me might be the "name",
    I use Windows XP Professional, yours might read Windows XP Home Edition.
    Change what you need "only" and save the file. Double check. Than remove the CD from your PC and shut down. Wait a minute and start it up.
    Dec 14, 2007 | Jetway 939GT4-SLI-G Motherboard
    SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
    469 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
