Question about Xerox Phaser 7300DN Laser Printer
A22 paper jamb won't clear
A22 paper jamb
  • 53 Answers
Reboot the machine:) its a definite fix
Posted on Nov 30, 2009
-A22, IC-A22E wiring digarm
Search at google for service manual of IC-A22E
Oct 22, 2013 | Icom CM-166 IC-A3, IC-A3E, IC-A22, IC-A22E...
I have a Sharp XE A22S cash register. After replacing the paper it just feeds the whole through.
1) make sure tour feed button is not depressed
2)Use the right paper i,e thermal, 57/58 x .....
Oct 19, 2013 | Sharp xe-a22s cash register, thermal...
Sharp XEA22S cash register....will it work without paper....we don't have any thermal paper and the cash drawer will not operate
No it will not. If you have bond (non thermal paper) it will work with that but you will not see any printing on the receipt. If you are still stuck, cut a piece of A4 paper to the width of the printer. Insert it in the printer and press CLEAR (CL). Once the machine accepts it, turn the receipt off and you can operate it without printing. Remember, you can't print end of day reports though. ------------------------------------------------------------------------
If anyone needs more information, the Sharp XE-A22s manual is here: http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A22S_instruction_programming_manual.html
Aug 20, 2011 | Casio Parts Cash Register PC Desktop
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My hp officejet pro k8600 won't print straight.
Jul 20, 2011 | HP OfficeJet Pro K8600 Printer
HP photosmart 8750 - cartridge cradle jamb error
You need to check the encoder strip, the clear plastic behind the carriage, ink or grease will stop it from reading and give that error. Also ink buildup on the clean station will slow it's travel.
Dec 22, 2009 | HP Photosmart 8750 InkJet Printer
Paper jam flasher
Henry, try blowing it all out with compressed air to clear jamb.
Nov 27, 2008 | Canon NP 7130 Black and White Copier
Paper light says on.. wont reset after jam is cleared
We have a few of the HL-2070N's and I have seen this issue on a few of them. Usually it indicates one of several instances that can be found on Brothers website in the FAQ's about what does the LED indicate area.
The main solution I have found is that depending on where the paper jammed it has affected the drum/toner cartridge assembly somehow or another.
  • I recommend taking the Toner Cartridge out of the drum unit
  • clean the corona wire by moving the blue tab at the front of the drum unit back and forth several times
  • I have even used can air here to get it even better all around the drum unit not just at the corona wire area
  • After make sure all is clean put all back together
This has cleared up most all of my paper jam LED issues and allowed for further printing.
Mar 28, 2008 | Brother HL-2040 Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
131 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
