Question about LG enV3 VX9200 Cell Phone
My camera is out of focus how do you fix it - LG enV3 VX9200 Cell Phone
My 24-105mm lens doesn't focus anymore. Neither auto focus or manual focus works. When I twist the focus ring nothing happens. I can't afford repair is this something I can fix?
I don't believe you can FIX it. Repairing cameras and lens is a quite specialized profession. Probably you can take it to repair but you say you can't afford.
So depending on your camera, you might sell it
Jul 13, 2015 | Cameras
How do i focus
These cameras do have a fixed focus. Perhaps the focusing is off, and should be adjusted on the camera. Please read the manual, for the specific way this camera works.
Dec 28, 2014 | Swann Communications PRO SERIES PRO-770 -...
The focus will not work.
some camera have fix focus (not autofocus), read the manual, find out about auto-focusing. if it's fix focus, sure you can't auto-focus it to certain object
May 27, 2013 | SVP Aqua 5800 Orange with Micro 32gb 18mp...
When taking a picture during nighttime, my camera only flashes repeatedly and does not take a photo, how can i fix this?
This is because your camera can't focus in dark. Your flash is triggering, trying to light up the subject, for the camera to be able to focus. If you focus manually the camera will be able to take a picture with out problems.
You could also light up the place you want to focus with a flash light or something, which will make the camera able to focus.
Feb 21, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
Im looking for a lens that i don't have to set up the focus. im taking a trip and my husband doesnt know how to use the camera and this 18-105mm lens needs to be focus if not then the image will be...
Sorry, but there is no auto focus or fixed focus lens available for your camera. You might consider purchasing an inexpensive fixed focus camera for your photo-challenged husband -- it will cost considerably less than an extra Nikon lens would.
Bill B.
Nov 01, 2010 | Nikon D90 Digital Camera with 18-105mm...
See-through lens is blurry and does not reflect the change in focus when I adjust the wide angle lens on my digital rebel xti. What's the problem and how can I fix it?
Check the AF/MF switch over the lens left side. Should be on AF to let the camera focus by itself. If not, you have to manually focus using the focusing ring.
If the camera is in AF and still no focusing, considere to carry your camera for service.
Aug 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Focus and or Zoom problem
double check that its still in auto focus, i went a whole day trying to figure out why my camera wouldnt focus, and i had auto focus off
Jul 12, 2008 | JVC GR-D770 Camcorder
Focus Problem
A small amount of dirt on the lens would just produce some flare and redule overall contrast slightly. It wouldn't produce a grossly out of focus image. Either you misaligned something or you messed up the autofocus system somehow. Can you focus the lens manually. Many consumer grade digital cameras allow you to set the focus at some specific distance. Do that measuring the distance carefully, and see if the image is still out of focus. Digital cameras tend to have a lot of depth of field, so there must be something seriously wrong with the mechanism.
Sep 12, 2005 | Fuji FinePix 2650 Digital Camera
Focusing Difficulties
1. Typical problem subjects for autofocus 1) Very low-contrast subjects 2) Overlapping nearby and distant objects 3) Very bright subjects in the center 4) Subjects moving very fast 5) Subjects through glass Focus on an object that is at the same distance as the desired subject, apply Focus Lock, and then recompose the picture. Or set the lens focus mode switch to (or), and focus manually. (Manual focus is only possible with cameras providing this feature.) 2. Attempting to take pictures out of the camera's shooting distance: When taking pictures out of the camera's shooting distance, the subject will be out of focus. The shooting distance differs from each camera model. Please check the specifications of your camera in the instruction manual to determine the shooting distance.
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
LG enV3 VX9200 Cell Phone Logo
217 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
