I have no sound on my gateway desktop..speakers are properly connected ...when i go to control panel it says no audio device
    Brigadier General:
  • 4,088 Answers
Probably there is no/corrupted sound driver software. Go to: Control Panel, System, Hardware, and Device Manager. Select the audio components and update the audio driver. If you have a plug-in audio card, try removing and replace the card (system shut down and power off) to renew it's contacts. Hope this helps.
Posted on Nov 17, 2009
    Novelist:
  • 132 Answers
If there is no audio device under the control panel, then your sound card might be faulty. Try to look in the device manager to see if the sound card is detected by Windows and try to update its drivers.
If you cant find it under device manager and it is not a built in sound card; try to physically uninstall and reinstall it.
If you had no luck on that, then you most likely will have to get another sound card.
Hope it helped.
Can you help me to reinstall my computer with no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 09, 2012 | Gateway Computers & Internet
No audio gt5622 windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
Aug 31, 2012 | Gateway GT5622 PC Desktop
There is no sound ..it is gateway desktop D4840 series
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 19, 2011 | Gateway DX4840-37 (PTGAU02040) PC Desktop
I attached the G-Max 2000 speakers that were on my XP Gateway to my Windows 7 Gateway. Though the device manager says they're working properly, no sound is coming out.
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 23, 2011 | Gateway GMAX 2100 Computer Speakers
My gateaway gt5040 computer does not have audio
hope this helps
Jan 22, 2011 | Gateway GT5040 PC Desktop
I have a dell dimension 3000 and i can't get any audio sound. it came with a samsung sw-2525 CD/RW . come to think of it i don't get any sound through the external speakers. it has no internal...
check to see the sound is working under the control panel .. system icon click and goto device manager
you might have a bad driver for the sound device or the device is bad on the motherboard
also test under sound devices.. and set the default device to use ..
Sep 28, 2009 | Dell Dimension 3000 PC Desktop
No sound from rear speakers Boston Acoustics BA 7800
check whether the wire is connected properly on both the ends
Aug 08, 2009 | Boston Acoustics (BA7800) Computer...
NO SOUND FROM SPEAKERS,ANOTHER PROGRAM USING MY SPEAKERS,GATEWAY COMPUTER
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Oct 05, 2008 | Computers & Internet
Unable to get any sound from the speakers.
or else
or else
should be same
Aug 11, 2008 | Gateway Computers & Internet
No sound from speakers.everything set up properly
or else
or else
should be same
Aug 09, 2008 | Computers & Internet
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
Electro Med Services...
