Question about Lexmark Pro X125 All-In-One InkJet Printer
Change ink prompt stays on after changing all cartridges.
  • 3,153 Answers
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a
chip resetter
around on the INTERNET or maybe even local
OR
Even better empty cartridges that
never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Posted on Nov 19, 2009
Mine does this all the time. I usually just ignore it, as the machine will print. The other day I had the change black cartridge message and needed to clear the internal memory for a different problem I was experiencing. When this was done, the cartridge message has disappeared. Try this, hold down the setup button. While holding it down, unplug the power from the BACK of the machine, unplug the USB cord from the machine. Wait for at least 30 seconds (this worked best when I held it for longer be patient!). Still holding that setup button plug the power cord in then the USB cord. Then release the setup button. The machine will do a couple of beeps and presto Ready prompt.
3 Suggested Answers
ybchuan
  • 201 Answers
SOURCE: changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Posted on Oct 26, 2009
Jaketech
  • 67 Answers
SOURCE: changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Posted on Jul 21, 2010
    We are trying to replace the black ink cartridge on our brother intellifax 2480C printer but even after loading the new cartridge the printer is indicating that there is no cartridge and the black ink...
    Did you have the no cartridge prompt on before you changed the cartridge? If no, then did you remove all packing material. Is this the first time you have changed the cartridge?
    Let me know
    Jan 09, 2011 | Brother IntelliFax-2480C Fax
    Changing ink?
    According to the set-up guide, if you open both panels to access the cartridge change area, the receiver should move to the middle and stay there.
    Here's the guide....
    http://safemanuals.com/annexe_Easy%20Setup%20Instructions_CANON_PIXMA%20IP4000-_E.htm
    If this is not happening, can you describe what is different from the set up instructions?
    Hope this is helpful
    Mar 06, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
    I'm trying to change an ink cartridge. Cartridges
    Usually the printer manual will have instructions on changing the cartridge. If you don't have a manual, there is a chance you can find one online by googling the make and model number. On some printers the cartridges center when you open a door to access them, or lift a lid or a scanner deck, or turn off or turn on the printer.
    Oct 03, 2009 | Office Equipment & Supplies
    NX400 printer - cartridge not positioned to change cartridge
    The problem occurs when trying to change a low ink cartridge before you are prompted to do so. In that event, you must go to setup, maintenace, change cartridge and it will move the cartridge into position.Do not try to force the cartridge into position.
    Jun 22, 2009 | Epson Stylus C86 InkJet Printer
    Changed ink cartridges - error still says I need to change them
    Call Epson tech support and then Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
    http://www.inkproducts.com/ink-store/
    Jun 20, 2009 | Epson CX8400 All-In-One InkJet Printer
    Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
    The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
    Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
    DCP-130C COLOR INKJET
    When inserting a new cartridge, you may receive a prompt
    "The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
    If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
    Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
    CHANGING INK CARTRIDGES
    For all printers I'm familiar with, it should be on. Some won't even move the carrier (the sliding thing the ink carts go in) over to where you can get to it if you open the cover with the power off. And you'll want to print an alignment page after replacing a cart too or your printout may be blurry (most printers will prompt you to do that after you close the lid).
    Aug 05, 2008 | Office Equipment & Supplies
    Changing ink cartridge
    Here is how to get the ink cartridges to move to the changing position on the R320.
    1. Press the paper jam/ink button on the printer control panel.
    2. A menu comes up. 1st item is ink cartridge replacement. Press
    OK button.
    3. Another menu with ink cartridge replacement. Press OK button.
    4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
    Hope this helps.
    Aug 05, 2008 | Epson Stylus Photo R320 InkJet Printer
    Lexmark Pro X125 All-In-One InkJet Printer Logo
    224 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
