Question about Technics Audio Players & Recorders
I have two Technics turntables with problems. I need to get a new rubber band drive for both machines. They are FGServo Turntable system SLBO1 and Direct Drive Automatic turntable System SLDD22. ZAlso, how does one attach the rubber band into the mechanism?
    Top Expert:
  • Technics Master
  • 77,186 Answers
  1. Remove the turntable rubber mat
  2. Take off the platter, sometimes there will be a circlip holding the platter in place and if this is the case it will need to be removed first. Most platters just lift off however.
  3. Turn the Platter upside down and you will normally see an extrusion where the belt goes round. If there isn't one and the platter has lifted off and left the belt in place then it will be obvious where the belt has to go! If this is the case then simply replace the belt and refit the platter. Now go to step 7. If however there is an extrusion on the underside of the platter then proceed to step 4.
  4. Place the belt around the extrusion on the underside of the platter
  5. Replace the platter.
  6. Grasp the belt through one of the holes in the platter and stretch it over the motor pulley. If there is a mechanical speed change guide you must make sure that the belt goes through this otherwise you will not be able to change speed.
  7. Replace the mat.
Posted on Nov 17, 2009
Turntable turns on, but it when i press play the plate doesnt spin. i noticed it budges like a mm but definetly not working
Turntable Drive Belt
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Feb 09, 2011 | Technics SL-1200 Turntable
When i press Start/Stop button, the platter is not moving/spinning. THe ON/OFF light is working, same as the pitch light and the lamp...
Feb 01, 2011 | Technics SL-1200MK2 Turntable
Where can I purchase a new rubber belt to drive my Servo Automatic turntable SL-B210 Ths is not an electronic belt
Here is a link for Technics Turntable replacement belts...just scroll way down the page for your SL-B210 belt listing $10.00. Hopes this helps.
http://www.turntablebasics.com/belts/technics.html
Oct 28, 2009 | Technics SL-1210 Turntable
The rubber band under the record player has come off
I am not familiar with your particular model of turntable, but typically the belt is easily accessible under the platter (rotating metal disc). Remove the platter (it often just lifts off, but don't force anything) and then you will be free to reattach the belt. Good luck!
Aug 25, 2009 | Panasonic Technics SL-DZ1200 Turntable
EVERYTIME I PLAY A RECORD IT DRAGS TO PICK UP SPEED
Are you sure you have a Technics SL1200MK2 Direct Drive Turntable? If so, then there is a major problem with the drive system. This can only be diagnosed and repaired by a qualified technician.
If your turntable is not the Techics SL1200MK2, and you have no idea what turntable you have, look at the model's label, if it says BELT DRIVE - this is the reason why it drags to pick up speed. If it says DIRECT DRIVE, then take it to a service center for repair.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 02, 2009 | Technics SL-1200MK2 Turntable
Turntable won't turn
Hi!
Without any other information (and assuming you've checked to make sure there is power to the turntable and that it is turned on), the likely culprit is the belt drive of your turntable. Most, but not all, turntables have a "belt" that looks like a big rubber band on the underside of the turntable that connects the turntable itself to the drive motor. If the band has slipped out of place, stretched too far from age or usage, or broken, the turntable won't turn. To find out if this is your problem, gently lift the "platter" straight up (it should easily slide back into place) and visually see if the "rubber band" is in place. If it is stretched too far or broken, a new one should be availble form Teac or your local electronics supplier. If, by chance, you have a direct-drive turntable (unlikely), the problem will probably need professional work.
Good luck and please let me know if this helps!
Bob
Oct 09, 2008 | Teac Audio Players & Recorders
Philco suitcase turntable / cd belt drive
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
Jan 27, 2008 | Philco (R) Suitcase CD Shelf System
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
