Question about Kettler Mondeo Elliptical Trainer
I just had the belt snap inside my trainer how do you fit a new belt on to machine?
    New Friend:
  • 64 Answers
The covers and at least one pedal arms to be remove. If I make no mistake you have to take the pedal arm a lose in the front to get the back off. You will need to do this to get the new belt on. Getting the covers off will be the most dificult part of this repair. It's not very difficult but more of a tedious task. Once covers are off you can see how belt was on. I normally look to see if there was a reason for the failure other than just being worn out. If everything looks fine replace belt and covers in order you took them off.
Posted on Nov 18, 2009
How do I lubricate the walking belt on a life touch elliptical cross trainer
as new, they should come with a small pot of oil. if you can get some silicone spray and spray it under the belt, as you hold the belt away with a wooden spoon so as not to damage the belt.
Merry Xmas
Dec 07, 2014 | Life Fitness X8 Basic Elliptical Cross...
What is an elliptical trainer?
An elliptical trainer is a stationary machine used to stimulate the action of running, stair climbing, or walking. It puts barely any pressure on your joints giving you a great non-impact cardio workout that can vary in intensity levels.
Aug 02, 2012 | Exercise & Fitness
Sunbeam 5891 Bread Machine The drive belt has fractured. How does one remove the bottom cover? Where may one obtain a new belt?
The upper and lower shell snap together. I removed screws from the bottom and could not separate the shell. I them unscrewed the metal shroud from the inside and removed it. It is a tight fit. You will see the snaps inside. I pushed on a couple of the snaps and the shell came apart. I am sure you will be able to address your issue from there. I am trying to find out why the heating element won't work on my machine.
Dec 03, 2010 | Sunbeam 5891 Bread Maker
V-fit herculean cross trainer assembly instructions
assembly of the wires for v-fit herculean cross trainer
Jun 21, 2010 | Body Solid G9S Multi-Station Gym
We have a Schwinn Elliptical trainer and the bar at the top part of the machine has completely come off. It is as if it has snapped at the base where it joins the bottom part of the machine. Is there any...
Call Nautilus @ 800-NAUTILUS (800-628-8458) if it is only the console mast and their is no more extensive damage to the lower frame and if the part is still available it might be worth your wild to repair the unit. If not junk the unit!!!
May 28, 2010 | Schwinn 430 Elliptical Trainer
Belt too tight to fit
the belt has to be tight so that the machine an work you have to get it over the pulley and it will work use a screw driver if you need to as a kind of prybar for it
Jan 26, 2009 | Hotpoint WF430 Front Load Washer
How to get back off to put belt on samsung b1445s washing machine
See if the motor has adjustment , ie a slotted fixing hole, slacken the fixing bolts slightly and motor may move up and down to give adjustment, put the belt on and then put some tension on the belt once fitted by moving the motor down and tightening the motor bolts at the same time.
Or if no adjustment put the belt on the motor spindle first and then the drum by turning the drum as the belt is eased onto it.
Apr 08, 2008 | Washing Machines
Kettler Mondeo Elliptical Trainer Logo
433 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Bill Eager
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
