Question about Cycling
How to change the pin code on an abus 1150 bike lock?
How to change the pin code on an abus 1150?
How to set combonation on Airbus Bordo Granite lock
Go on line to the manufactures web site and seek a new manual download from the support division.
May 10, 2014 | Abus Cycling
Lost pin and key fob to turn on bike
Simply put, you cannot. You will have to replace the TSSM module if you want to keep the immobilizer and alarm or replace it with a TSM module which will have no alarm or immobilizer. Even a dealer cannot start this bike without a pin. If the bike was PDI'd correctly, the dealer may have set a standard pin code and as long as the owner did not change it happy days. On the other hand, if no pin code was set, then you are out of luck. No fob, no start. Check your owners manual to see if the dealer wrote the pin code down. Also, he may have stuck two stickers which will have the codes of the original fobs programmed to the bike. If you have these, he may be able to order a fob with matching codes. Best of luck.
Feb 24, 2014 | 2013 Harley Davidson Electra Glide Ultra...
Can i change my processor? AMD LE-1150 to dualcore or core2duo?
If your using AMD LE-1150 you cant use a dualcore nor a core2duo because the socket of your motherboard is for AMD microprocessor only you can upgrade or change your procs to any AMD AM2 dual core model make sure you check the specs of your motherboard for supported CPU list. you can find that in their website
Apr 27, 2010 | AMD Sempron LE-1150 2.0GHz Processor -...
K1100 LT motorcycle radio
there should be a radio book with the bike and its in the book
Apr 05, 2010 | 2004 BMW R 1150 RT (ABS)
Bike is not selecting E gear when changing gears
its in the gearchanging mechcanism,worn,, slipping,,loose bolts on selectors splines worn or broken the pegs on the selectors broken so not engaging with the slots in the gearchanging disc
Nov 17, 2009 | 2004 BMW R 1150 RT (ABS)
Wont play dvds
does the dvd need cleaned
have you tried devices to update driver
have you right clicked on the drive and properties to see if any settings were changed
Jan 22, 2009 | Dell Inspiron 1150 Notebook
Keypad lock for k750i
You can't lock it with a code, unfortunately, the best you can do is to do a key-lock, which you can do by pressing the * button, and then the right contextual button (the one right underneath your screen).
If you're worried about your phone being abused, you could consider setting a SIM PIN code, but this requires you to turn the phone off for it to be active.
Apr 15, 2008 | Sony Ericsson K750i Cellular Phone
Cycling Logo
536 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
