Question about Radio Shack Radio Communications
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
20 Channel SI & S2 To enter the FREQ 1 PUSH MANUEL
2 Enter FREQ
3 PRESS ENTER
4 Press Channel Number
That all works, but does the Unit Automatically scann all channel's S1&S2? For S1 i start w/channel 1! For S2 do i start with Channel 11?
And i thank you very much for the help.
BILL
You can program a different frequency on every channel, then press scan to auto scan every channel, press the ./ delay button so the unit will delay on the channel momentarily, then continue to scan when the transmission is over.
The s1 and s2 buttons are used to scan the frequency band. For example: i want to scan the band from 45.000-49.000. I press search program, enter the frequency, press enter, while s1 led is flashing, press 1, then enter the ending frequency, press enter, with led flashing, press 2, then press search scan. The unit will now scan every frequency between the two frequencies.
Posted on Jan 15, 2012
  • 31 Answers
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Posted on Nov 18, 2009
Scanner stuck on one channel and won't allow me to enter new freq
Push the "L/O" lockout button and it will lockout that channel.
When you press "Scan" you have to have at least one of the banks scanning, so press 1, 2, 3,....9, 0 whatever bank you have channels programmed in order to automatically scan. You should be able to press "Manual" to see each channel individually.
May 07, 2014 | Uniden Bearcat BC 220XLT Radio Scanner
Regency R1077 base scanner can not delete old frequencies to reprogram scanner
Press "Manual", then press digit key ("0/10" thru "9") that corresponds with the channel to be changed ("0/10" = ch10). Next, press the digit and decimal point keys to enter the frequency in megahertz (Mhz) to be stored in the channel. To store 453.100 Mhz in channel 2, you would press "Manual", then "2". Press the following keys in order: "4" "5" "3" "." "1" "0" "0", followed by pressing the "Enter" key. Repeat this process for up to 10 channels.If you wish to clear unused channels, you should be able to select the channel, then enter "." followed by the "Enter" key.
This scanner will only accept frequencies between 30.000Mhz and 599.999 Mhz. Attempting to input frequencies outside this range will result in an error message.
I hope this helps and good luck! Please rate my reply. Thanks.
Jul 11, 2011 | Radio Shack Pro-96 Scanner
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
Trying to program it
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
Once you have your freq list, power the scanner ON,and:
1. Press PGM. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the keys to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel. Press DELAY if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends.
4. To program the next channel in sequence, press PGM and
repeat Steps 2 and 3.
Operation
• To listen to a weak or distant station, turn SQUELCH counterclockwise. If reception is poor, turn SQUELCH clockwise to cut out weak transmissions.
• If SQUELCH is adjusted so you always hear a hissing sound, the scanner will not scan or search properly.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
BillB
Jan 09, 2010 | Radio Shack Pro-2018 Scanner
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
SKIPPING BANKS
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
SEARCHING WITH YOUR PRO-2021
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
Jan 07, 2010 | Radio Shack Pro-2096 Base Scanner
How do I program a Regency Z30 scanner?
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you want to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission to wait for the next response, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Jul 10, 2009 | Radio Communications
Help me put new Frequencys in my scanner
Here is the link to all Uniden scanner manuals:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Also, you can find the frequencies for your area at www.radioreference.com.
May 20, 2009 | Uniden BC60XLT-1 (30 Channels) 2-Way Radio
I dont no how to program my regency z30 scanner
1. Press "MANUAL"
3. Press "ENTER"
If you wish to add more frequencies at this time, got to step 2.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
Apr 07, 2009 | Office Equipment & Supplies
How do I program a Regency Z45 scanner
01) Press Manual to enter the manual mode.
02) Enter frequency.
03) Enter channel number (e.g. for channel 1, enter 01).
04) Press Manual again.
Note: When entering a number of channels, you can start at step 2 after the first frequency is entered.
Mar 14, 2009 | Office Equipment & Supplies
Programming
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
Radio Communications Logo
1,010 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
