Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Steam vac is not sucking up moisture like it should. The dispenser is dispensing the solution and it sucks a little, but not like it should.
Check hoses for possible leaks.
Posted on Nov 21, 2009
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Steam Vac Is Not Dispensing Soap
Try using a rubber tipped air nozzle and compressed air at the end of the soap dispenser line. Brief intermittent blasts of air should take care of it.
Nov 16, 2013 | Hoover F6212-900 / F6215-900 SteamVac...
Bissell powersteamer will not dispense water
calcium deposits from hard water... run vinegar and hot water through it a few times.
Mar 19, 2013 | Bissell 1699 ProHeat Clear View Upright...
The Bissell won't spray any carpet cleaner but it is still sucking up water.
If it doesn't dispense water then that means that you need to replace the pump belt. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
Every time i push the steam vac forward it dispenses water
you are having the same problem i am and so far the best solution i have found is i need a new clean tank just got my steamvac today bought it cheap so not complaining much the other solution i found was to only have the cleaning solution tank in for as long as i need it if i put the cleaning solution on the floor then take out the clean tank the dirt tank still sucks up the water
Godbless and Goodluck ...by the way just in case you dont have it here is the manual for your model
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Jun 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Solution tank does not dispense--recovery tank still sucks up dirty water from tile floor on screen porch. I applied cleaner manually with a scrub brush and sucked it up with the hoover steam vac deluxe.
Check to see if the when you squeeze the trigger, the rod is hitting the reservior asm(tank sits on). If not then there is a problem inside the handle and the rod. If it is hitting, then the reservior asm. is bad. Also make sure fluid is coming out of the tank when you push the vavle in at the bottom of the tank.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
had my steamvac spinscrub for 3 days now. it will not **** up why?
Jan 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water tank doesn't dispense water
water is not coming out or sucking up water
Aug 24, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
229 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
