Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
No fire to moter with good battery - Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
  • dontbother10
    dontbother10 May 11, 2010
    Hello, we are having a problem with self rating by our experts. If you did not rate this or do not believe it warrants a rating of very helpful please rate it as NOT HELPFUL. Experts cannot override your rating and seems to be the only way to stop this practice.
Why does my quadra fire 1000 not lite..i checked blower moter ignighter could it be thermocouple?
Wood burning or pellet stoves create acid vapor. The vapor damages thermocouples faster than a gas stove.
Jan 17, 2016 | Cars & Trucks
I turn moter over but its not firing I ark the battery acaccident and now wont start its a 94 four door lexus es 300
follow battery positive cable from battery should be a junction that junction unit should be your fusible link or known also as master fuse also check start and ignition fuses /relays
Aug 02, 2015 | Lexus Cars & Trucks
My 94 s-10 4.3 running good back-fired 2 times then quit. moter turns will not run.
no idea iam a europen mechanic but if this vehicle has a timing belt then check this first
Jan 01, 2013 | 1994 Chevrolet S-10
Ford transit T reg 1999 does not start when engine cold battery good but will bump start . When starting engine turns slowly.
hi mate it sounds like a lazy starter moter but failing in that a one off problem is try changing your oil yeah it sound silly but a have had one in the past and that was the problem as the oil sank to the sump over nite and caused it like a dry friction once it was started and oil was up it would fire all day
Jan 26, 2010 | 2000 Ford Focus
Wont start
Sounds the starter is no good (sometimes they'll work intermittently for a while before they totally **** out). Of course it could just be a starter wiring problem (sending wire).
Mar 12, 2009 | 1997 Ford Expedition
Silonoid clicking but won't turn over
have no solution but exact same problem on a 97 Grand am.... i'll be watching if there are any good solutions!!!!!!!!!!
Jan 12, 2009 | 1989 Jeep Wrangler
Moter terns but dont fire
I had a bad ground to the injectors, the ground is under the intake manifold
Jun 02, 2008 | 1998 Toyota T100
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
70 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
