Question about Omega 8005 Juicer
Omega 8005 juicer problem
Hi
Have been using my Omega 8005 juicer for 5 weeks. Just recently it has been getting really clogged up and backing up which means I now have to clean it out half way through making 1 pint of juice. I used to be able to make 3-4 pints without any clogging problems. I have been using carrot, celery, beets, cucumber for the entire time so dont understand why I am now having problems. Any advice would be much appreciated.
thanks
3 Suggested Answers
sweetymommy
  • 4 Answers
SOURCE: wheatgrass juicing problems
Hi, I have an Omega juicer, and I've never had this happen. I recommend that you double check to see if you have the right parts attached. It comes with two inserts, one with a small metal screen on the bottom, the other has no screen, it is solid. The solid one is for crushing and proccessing food. The one with the screen is used for juicing. Make sure you have the correct one installed. If that is not the problem, I think perhaps the grass is too dry? Maybe there isn't enough moisture in it to extract much. I really can't say, though. Try juicing something else, like carrots, and see if you can get some juice there. If all else fails, contact Omega at their website. They have terrific customer service. I've tested it already with a warranty replacement.
Posted on Aug 06, 2007
  • 7 Answers
SOURCE: omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Posted on Jun 30, 2009
Where do i send my omega juicer to for repairs?
Omega Juicers Repair Form
This is a link to the official repair form for all Omega Juicers.
Jul 08, 2015 | Omega Juicers
My juice is coming out with the pulp. The machine seems to be operating and sounding normal and this has never happened before. I have the omega 8005 model??
This usually is indication of pulp backing up in the machine make sure you are pre cutting the produce and also make sure the tensioner on the end is adjusted according tot he produce being used. Example: softer produce requires less tension where as leafy green vegetables you can increase the tensioner.
Feb 03, 2013 | Omega 8005 Juicer
When we juice, it turns and moves across the counter
Both the Omega and Acme juicers vibrate no matter what you do. I found a worn shredder
blade actually produces less vibration. However this involves filing the cutting burrs down
and resetting the blade to chute gap. If you're up to it, take the blade out and file each row
of burrs about halfway down. Then with the juicer fully assembled, unlock the set screw on
the center of the bottom, turn it clockwise until the chute contacts the blade, and back it off
a half turn. The set screw actually raises and lowers the motor spindle. Both companies
would not agree with this, but this solution comes from operating my 21 year old Acme.
I recently replaced the blade and the juicer immediately began tap dancing. Went back to
the old blade.
Jan 16, 2011 | Omega 1000 Juice Extractor
Omega 8005 juicer will not start
Jun 30, 2009 | Omega 8005 Juicer
Wet pulp
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Jan 05, 2008 | Omega 8005 Juicer
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Oct 31, 2007 | Omega 4000 Juicer
Wheatgrass juicing problems
Aug 05, 2007 | Omega 8005 Juicer
Omega 8005 Juicer Logo
93 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
