Question about Canon imageRUNNER C5180i Color Copier
Canon imageRunner C5180i Color Copier will not allow multi tray
I am attempting to print a brochure on one of my color printers at my work and when I go into the printer settings, it will not allow me to select a tray that is on the printer. It is only showing that 2 trays are active when there are a total of 4 trays on the printer. I have the printer installed correctly. Is there a way I can activate the other trays on my computer?
  • 2 more comments
  • Nicole Hoy Nov 18, 2009
    That's great. Thank you. Yes, it is XP, XP Pro SP3. When I go into the Properties of the printer itself, there is no "accessories" I get a bunch of tabs and none of them are accessories. If it is in a sub directory of one of those, great but I am not finding it.
    The tabs I have are General, Sharing, Ports, Advanced, Color Management, Security, Device Settings, and Profile. I do not have accessories.
    Also, it is on a print server originally that I installed locally so that I could use that third tray.
    Thank you! Okay, now the next issue I am having with the same printer is that I cannot print multiple copies of the same thing to this printer. It will only print one sheet so if I want 60 copies of something I have to go in and do a file -> print 60 times to get 60 copies. Any idea on how to fix that?
    Yup, I did do that and still only prints 1 copy. I put in 60 into the box but it only printed 1.
  • 1,110 Answers
XP? or similar then go to printers list and double click on the Canon 5180. Then click "Printer" then "Properties" then "Accessories"
Make sure on the options listing that the tray 3 and tray 4 are "installed" or their boxes are checked. This is the only thing I have ever seen cause you not to be able to access certain trays or other options.
Good Luck
Posted on Nov 17, 2009
Testimonial: "Thank you so much for your help thus far! You've been very knowledgeable and it is of a big help."
  • 2 more comments
  • Edwin Martens
    Edwin Martens Nov 18, 2009
    The screen with the bunch of tabs should have the following tabs:
    General, Sharing, Ports, Advanced, Color Management, Accessories and Advanced Options
    The screen with the trays and other options to install is the accessories tab. I do not know why this tab would not be there on your machine. I have used this tab on numerous XP machines including Canon printer/copier installations.
    You could also try deleting then re-installing the C5180i if need be to get the trays set correctly.
  • Edwin Martens
    OK on my Canon C3170's the paper tray options are under the Device Settings tab. Top right of that tab you should have a box unchecked that says 2-cassette feeding unit. That box once checked will show your copier with 4 trays instead of the factory 2. You should actually see the 2 trays appear on the copier pictured when you check that box.
  • Edwin Martens
    So when you click print and your print screen comes up....you have a box to the lower left that says "Number of copies" with an up/down arrow that you can change from the default setting of 1 to 10 or 20 or 60, whatever you want? Does changing this make the machine print 60 copies of the page? Perhaps you tried this I am just making sure.
    You don't have to use the arrow I am just trying to keep things simple.
  • Edwin Martens
    Then my only other suggestion is that there is either a setting on your print server that is regulating the multiple copies or possibly a security type setting on your network. I know the Canon's have some other securilty settings that lock out color usage and what not so could be something there too.
    Sorry I can't help you much with this problem.
Error
Turn the Main power switch off then back on. If you want a better answer try to let us know what the error code that is displayed on the display. There are ruffly about 100 or so error code. Good Luck
Jun 16, 2012 | Canon imageRUNNER C5180i Color Copier
Can I turn the color off my Color imageRUNNER C3220 and only allow black printing?
goto the printing preferences in the driver menu and then set the profile for the preferences for the setup u like to use .
Sep 08, 2011 | Canon imageRUNNER C3220 Color Copier
Error code E000020-0260 on a Canon C5180i
It could be that the developer is not being supplied to the developing unit.
Also the thermistor as detected a high voltage caused by the power supply.
Therefore, two thing problem in the developer and the power supply to the fixing assembly.
Jul 15, 2011 | Canon imageRUNNER C5180 Color Copier
We have a Canon color imageRunner 5080 that is set up to print from several computers. One computer will no longer print to the copier. The problem started after our power went out during a...
check the network interface of that computer. it might have blown during the storm.if all others are working that means the networking is ok and only that computer is not on network.replace it with a new network card,assign ip address and thats it.
Jun 17, 2011 | Canon imageRUNNER C5180i Color Copier
Where is meter reading on canon imageRunner C5180i color copier?
Hi sophie,
Look to the far right of the operator contol panel, past the 9 key pad and you will see a "little button" called COUNTER check. Press it and it will tell you your meter reading.This screen can be configured "by a service tech" to allow you to view the count of up tp 6 different meter counts depending on the function you wish to monitor. The basic meter reading is named "101". That because there are hundreds of funtions that are always monitored and they name them 101,102,103 etc. 101 counts the number of sheets of paper that have exited the copier. "102" does the same except it counts 11x17 [ledger] as 2 copies as 11x17 is really 2 letter size sheets. So my company uses this meter for billing purposes so we ADD the 102 meter to the list of viewable meters. Again this can be configured to the customers needs or the service provider needs. You can set it to view just black and white, just color, or even how many copies were made at 64%. its wild. But the 101 meter is the default and cannot be removed or altered. I sure how I helped you. Please let "FIXYA" know.The pat me on the head when I do good. :-) Take care . SPINAL
Jan 28, 2011 | Canon imageRUNNER C5180i Color Copier
How do you get print log detail from previous days- IRC5180
Use the RUI from your pc. Type in IP address of printer in internet explorer address bar. Then you can select the print log for further back. This feature has lots of event information stored on the copier hard drive.
Jun 10, 2010 | Canon imageRUNNER C5180i Color Copier
I can't get my Canon ImageRunner 3570 to print in color, how do I get to that setting?
The Canon IR-3570 is a black and white copier, printer only, it's is not a color printer. sorry
Dec 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Only on color printing am I getting ghosting of the images. How can I adjust this?
hello,when i see one color dusting, ghosting i usually change that color drum unit.If multi color ghosting probably the transfer belt cleaner blade.thanks don
Nov 10, 2009 | Canon imageRUNNER C3200 Copier
Want to change the default to black & white not auto color
you set the settings the way you want on the copy screen ane then you store the settings under additional functions/common settings/store i believe
Mar 18, 2009 | Canon imageRUNNER C5180i Color Copier
Canon imageRUNNER C5180i Color Copier Logo
286 people viewed this question
old marine
old marine
