Question about Garmin iQue 3600 GPS Receiver
Garmin ique 3600 won't turn on after battery goes dead
Hello.
i have the above model and when the battery runs out, it goes dead of course. the problem tho' is that when i put it on charge, the green light on top blinks and after a while when i try to turn it on, nothing happens. well, sometimes it works, sometimes it doesn't. i also know that the battery is good. is there something i'm not doing right?
thank you!
  • 174 Answers
You have to charge the unit before it will start from a dead battery (usually about 10 minutes) before even trying to start the unit.
Posted on Jan 28, 2008
Worked for me thanks
Posted on Mar 26, 2008
Actually i figured something else out.(tried your solution and didn't work for some reason). i just reset the device and it come right on, careful tho, don't erase your data, unless you want to. so the reset worked every time.
Posted on Jan 29, 2008
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
I have a buzzaround model #gb 101. the light is green. but i noticed the reset button is pushed under the deck that you put your feet on. could that be why its not running? even tho the light is gree
Lift out the battery module below the seat. Turn upside down remove about 8 or 10 little screws. Look inside for a wire connection that came off one of the 2 batteries. Also check the inline little fuse. Check ALL wire connectors as a lot of these come loose. Note, the circuit breaker will be popped out if tripped, IN is OK.
Apr 04, 2014 | Golden Technologies Buzz Around 3 Wheel...
Battery light flashes green 5 times then changes to orange.
What is the make and model of your laptop? What operating system is being used?
Dec 05, 2017 | Dell Latitude D610 Notebook
Kodak easyshare m320 charge light is green, but not charged
Hello Dead Battery, Well this sounds pretty easy compared to most questions I get. If the camera says the battery is dead, then the battery is dead !! the problem with batteries is they loose their capacity over time. The charger can not put any more in it and says it is charged. Just get a new one and give it a full charge and this should do the trick.
Best Regards, Russell
Sep 29, 2012 | Kodak EasyShare M320 Digital Camera
Engine wont start right up take few minutes engine runs like **** longer it runs better it runs then today that altanater light comes on and battery goes dead so i went to charge it wont charge the...
the alternator is definately bad, if it ran your battery dead like that, and of course as you can tell your battery is trash and needs replaced.. not sure what to tell you on how it runs, considering once it warms up it runs good.
Dec 05, 2010 | Acura TL Cars & Trucks
Charger model FY 4101 green light stay lite all the time, and hoveround battery is still dead
When the green light stays on regardless of dead battery, this means the battery is defective. The battery must present a load to the charger, which causes the charger voltage to drop, turning the charger on. When the battery is defective, it will not load the charger, and the charger voltage stays at full charge value. This of course, causes the green light to be switched on.
Sep 16, 2010 | Electronics - Others
Battery charging issue
How old is the battery? They're only meant to last a couple years at most. If older, it's time to consider a new battery. Fortunately, generic batteries for your camera are very inexpensive these days. Here's some examples from Amazon. Some are better than others, so make sure that you read the reviews:
Jan 15, 2010 | Canon IXUS V2 Digital Camera
Red light keeps comming on and battery goes dead.
Alternator and stator....put a voltmeter on the battery - it should read about 12- 13 volts. Then start the bike.... when its running, the volts should increase.... if it doesnt....your charging system isnt working.
Jun 27, 2009 | 2006 Harley Davidson XL 1200 R Sporster...
18volt ryobi battery charger doesnt work
try pitting battery in charge and wiggle the battery a little to see if the green light comes on, sometimes the make contact and then loose it when you let go of the battery.if still same problem charger is probbly dead.
May 17, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Garmin ique 3600 not working
Been there. If the unit will not reset with the hole in the back poke you need to disconnect and reconnect the battery. Use a small torx screw driver for the four screws in the corners. Gently split the back case off by the thumbwheel and pivot it around. the battery connector is a small white connector in the lower left hand corner. Be careful of the power switch, ir lamp cover, and plug gasket since when you open the case they sometimes make a break for freedom.
May 08, 2009 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
596 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
