When i plug it in it keeps making a clicking sound and the light flashes and it will not open any documents stored on it
  • 358 Answers
Please note that: a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, then it means that you have some hidden partitions on your external drive, so when you plug it, try and do this:
Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Also Make sure that the USB port that you are using is a USB 2.0 port, and not USB 1.0 port, you can just try the other ports there, to be sure.
Hope this helps you out.
Posted on Nov 18, 2009
Thanks so much for this; i was in despair because i plugged in a new external harddrive, which somehow took the position of the existing one i had been using and then when I was trying to use my itunes library it couldnt find any of the songs. It wouldnt recognise my existing hard drive as f:/ any more; only g:/ no matter where i plugged it. I thought Id give this a try because it sounded like what i needed and hey presto... i have music again!!! Thanks so much
Posted on Jan 08, 2010
Plug in and red light flashes and makes a click sound
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | JVC AV-32850 TV
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
I dont know how to make background on my usb please help me.
These instructions will make your flash disk more "personalized". You can use any picture you want.
The end result will be viewable from any pc you plug your flash disk into. You only need notepad to code it.
Then you can show off anywhere
HERE ARE THE 4 STEPS YOU SHOULD REMEMBER
STEP 1
Preparing the Picture
Of course, you must have a flash disk to do this. Once you plugged in the flash disk and open it via explorer, make a folder named "background" or whatever name you want. Then, put any picture you want in that folder, but you should remember the folder and the picture's name. Right click at the folder, then open properties. Check the box beside "hidden" to make it unseen, and making your flash disk neat. You can place the picture you want to use in any folder you want, even existing folder. The only difference is the coding of the desktop.ini file at the next step.
STEP 2
Coding the background.ini
Now right click anywhere in the flash disk, (not in the folder you've just created) and open a New Text Document. Just ignore the new document's name because it will be deleted later. Open it using notepad and use theese code for the template:
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Text=0xFFFFFF
[.ShellClassInfo]
ConfirmFileOp=0
IconFile=%SystemRoot%\system32\SHELL32.dll
IconIndex=43
IconFileOld=%SystemRoot%\system32\SHELL32.dll
IconIndexOld=43
Then save it as Desktop.ini and delete the old New Text Document.txt
other filenames will not work.
See picture for notes on editing the code.
Then you're done!
You're done. You can show off at your school's computer lab, in your friend
Feb 04, 2011 | Computers & Internet
How do I send a works document to my flash drive?
All you need to do is plug in the Flash drive on to the computer, it will detect the flash drive and create a drive sysmbol under MY Computer or Computer", select the document that you wish to copy, right click on the document and then click "Copy", Go to "My Computer or Computer", double click on the Flash Drive icon, it will open a new window, right click there and click "Paste", that's it
Thanks and regards,
Anil.B.R
Sep 07, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to unlock locked Sony VAIO documents?
Right click on the documents (or the folder containing the documents)
Now select "properties"
Depending on what version of windows you are using there will be some differences.
On Windows 7 for example, you now click on the "General" tab.
You will see a check box for "read-only". Make sure this is turned OFF and then click "apply".
Good luck.
Jul 22, 2010 | Sony VAIO Notebook
How to use a flash drive
It doesn't matter to which USB port you connect the flash stick.
It should appear as an additional disk in My Computer, with a total capacity close to the rated one. To identify which drive letter is it, observe the open My Computer window and plug (or unplug) the stick - it will be the drive that appears (or disappears respectively) from the screen.
How to use it? I prefer not to use any special backup software, which I find not very intuitive. I just make folders that make sense for me, and copy the files (that I want to back up or transfer to some other location) to these folders.
Dec 29, 2009 | Computers & Internet
Storing documents on my sandisc cruzer 4.0GB flashdrive
Scan the pendrive for virus infection, that may be the possible cause.Or try formatting it once and then check again if you cannot fix it using a antivirus.
Jun 24, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I can not get any audio on youtube.
make sure you have Adobe Flash player installed on your PC.
And that your browser isn't blocking the content.
If you can't hear sound within videos embedded on other websites or blogs,
your computer may be blocking third-party Flash content. To correct this, follow the steps below:
  1. Visit http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager03.html
  2. The Adobe Flash Player Settings Manager should display.
  3. Check the box labeled: "Allow third-party Flash content to store data on your computer."
  4. To ensure the check sticks please click one of the tabs at the top of that box and then click back to the (Global Storage Settings Panel). The box should still be checked.
  5. Once this is complete, close all browser windows and try playing an embedded video.
Please be advised that this action stores a Flash cookie on your computer. Flash enables this by default upon install.If this step doesn't help, please check your Antivirus and Firewall software to see if you're blocking third-party Flash content.
Mar 13, 2009 | HP Pavilion Media Center a1330n - AMD...
8 gb flashdrive by gigabank has malfunctioned. Is there any way I can retreve my data from it? or, repair it?
Yes, you should make sure its plugged into the USB port. Then Open My Computer by double clicking on it.
Look for your Flash Drive and double click on it.
When it opens you can highlight what ever you want to move and right click on one of the highlighted icons and click cut.
Then go back to My Computer and click on "C" drive and go to Documents. Then open the documents and right click and paste . That will move the data.
Hope that helps. Bud
Jan 21, 2009 | Computers & Internet
Flash drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. When it opens right click on your mouse over the document you need and click send to: desktop, ect. Let me know what happens.
cynthia
Jan 11, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
681 people viewed this question
David Payne
David Payne
