Question about Acer TravelMate 4062WLMi Notebook
Wi fi on ACER Aspire 4810T connects intermittently
Wi fi modem on ACER Aspire 4810T connects only intermittently via router (on ADSL line)
works in some places (cafes) but not at home- alternates between full internet access and local only
it is only a few yards from the router
  • 92 Answers
Log into your router and change the channel and see if that helps. Failing that try rebooting the router to factory settings and deleting your connection from the laptop. Then start from scratch again...Hope this helps...Please let me no...
Posted on Nov 18, 2009
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Bsnl broadband modem
Indian Telecom gaint Bharat Sanchar Nigam Limited (BSNL) has introduced 4 types of ADSL Broadband Modems(ADSL Basic Modem(CPE), ADSL WiFi Modem, ADSL WiFi-TA Modem & VDSL WiFi Modem) with Ethernet, Wi-Fi , USB, and Terminal Adapter port.
Which version have you got?
Feb 10, 2014 | Acer Computers & Internet
Can't download anything on my Acer Aspire 5552-3691
I don't see a question above, so I'll just assume that you're asking how to fix your computer so that you can connect to the internet. Is that correct?
If so and since you have reset your computer back to factory settings, you should check that all of your software is updated to the latest versions. This would include your operating system and drivers.
Then, you should check that your computer can connect to the internet via ethernet (RJ-45) cable. You would want to directly connect your laptop using the ethernet cable to your router. If this works, you can move on to trying to connect via Wi-Fi. If this doesn't work, you should check that there are no software/driver issues and/or hardware issues with your computer.
If you are trying to connect via Wi-Fi, again you will want to check that all drivers and software are up to date (so that you are on the latest versions of your operating system and the Wi-Fi care inside your computer has the latest driver so that it can connect to your wireless router). Then you will want to attempt to connect and most likely re-input your Wi-Fi password.
Dec 30, 2013 | Acer Aspire 5552-3691-24271 Laptop
I do not know how to connect to internet thru wi-fi with my aspire 4738Z
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 21, 2011 | Acer Aspire 4730-4947 Notebook
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
I have a ASUS RT N10 Wi-Fi Router. I connected the wi-fi Router to my Desktop after-which I am not able to access the Internet. If I connect my desktop directly to my ADSL Modem, I am able to connect to ...
Check to see if you can plug the wan port to your adsl modem and then plug your pc to the router. on ADSL, some ISPs will record your mac address to avoid sharing. Just see I your router supports cloning your mac. All you do is login to your router from your pc, and it should be under your Wan settings. Use DHCP unless specified otherwise, and ensure to enter any pptp login info if your ISP provided any.
Dec 27, 2017 | ASUS EZ N Wireless Router up to 150Mbps...
Speed is very slow from modom
Try not use a modem when you have a Router,Connect the ADSL cable Directly from the Spliter to the Router and try using it.
Router does the same thing which modem does but wi-fi connectivity is found in routers.
Nov 27, 2010 | Cisco Linksys E1000 WirelessN Broadband...
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Computers & Internet
Linksys speed cut off
First, are you connected via Ethernet cable or are you linking via Wi-Fi? If Wi-Fi the speed is alway slower (up to 54 Mps) If connected by Ethernet, your connection speed should read 100 Mbps. Once you have determined the connection mode and speed.unplug the wireless router and connect the computer directly to the modem. Now test the speed and see if the speed lag is still ther. If not, you have a routing /networking issue but, it it is still the same speed, it could very well be heavy traffic ( a lot of people drawing from the same local area signal., usually at specific times of the day).
Nov 24, 2009 | Linksys Wireless-G WRT54GL Router
I cannot connect my IPOd Touch to the internet to download music . I need wi-fi connection. I already have internet service. What is wi-fi and how do I get it?
Wi-fi is wireless internet. Wireless internet is aquired via a router that supports wireless internet. The router is connected to your modem which supplies your internet.
Sep 29, 2009 | NetGear DG834G Router
Acer TravelMate 4062WLMi Notebook Logo
385 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
