Question about Bosch 22 in. SKT5108 Free-standing Dishwasher
Dishwasher fills and appears to be going through cleaning cycle ok. However if I open the door part way through the dishes appear as though nothing has happened, dishes are still dry and dirty. have checked hoses, manually added water, observed emptying etc. Any ideas nost welcome, Thank You
  • drallim May 11, 2010
    Either the water pump is not working, or there is blockage in the deck where the water is supposed to enter the pump. You may have to tear the lower spray arm and components down to the deck to find the problem. Look particularly for a large screen near the bottom that is supposed to filter the spray water before being pumped. You can clean this screen with a hot water, white vinegar, and detergent solution. Note the order and orientation of each part removed. Check the holes in the deck for food plugging. If you have access to a wet-or-dry vacuum, that can be used to **** out debris from these holes. Hope this helps.
    Scholar:
  • 111 Answers
Most of the time it's because the impeller assembly has either something stuck in it or has just plain worn out.
Also you want to check and make sure the holes in the washing arms are clear (Poke a little toothpick threw them, or small piece of wire/nedel ect).
To get access to the impeller, involves unhooking the power, water and drain line.
Turn the entire unit upside down and remove the plastic impeller, which there is a kit that can be purchased at most local appliance parts suppliers with the model and serial of the unit, to replace just the inner working parts of the impeller assembly.
Just think like a dishwasher and where does the water come from and follow all the pipes and be observant to how it is getting to the washer arms.
Good Luck!
FlaTech
Thank you for using FixYa!
Posted on Nov 17, 2009
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
I am having issues with my dishwasher where it appears to be working but does not clean. Hot water does enter the unit and drains properly but is not cleaning. Muck is still on the door, the arms are wet....
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Mar 04, 2011 | Dishwashers
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Why won't my GE dishwasher get my dishes clean?
IF all appears to be working just leacing film on dishes or if not actually cleaning dishes there could be several things it could be... the basics to start with are first make sure the entering water temperature to dishwasher is a t least 120-140 degrees ... run water at sink prior to starting dishwasher.. next remove drain line from under sink and check for any obstruction where it connects. check the area under lower spray arm for trash/food build up and if you can remove spray arm and clean port out of any calcium build up... make sure the water is filling unit properly run a cycle and when you start unit listen when it stops filling open door and make sure it has enough water in it.
Jan 27, 2011 | GE Dishwashers
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes don't get clean
Remove the bottom screen assembly and look for debris, like pieces of plastic film and grease, that are blocking water access to the pump impeller intake. Sounds like flow is low and that means to look at the pump intake.
Sep 26, 2009 | Whirlpool Dishwashers
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Not cleaning dishes
sounds like you are not getting enough or any water a check the water level when it fills... let me know
Apr 05, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Bosch 22 in. SKT5108 Free-standing Dishwasher Logo
161 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
