Question about Microsoft Xbox 360 Console
Xbox no hdmi signal be recieved on tv - Microsoft Xbox 360 Console
  • 456 Answers
Make sure that your tv is on the HDMI input and the xbox av cable is on the HDTV setting. I hope this helps. Good Luck.
Posted on Nov 18, 2009
2 Suggested Answers
pwningnoobs8
  • 74 Answers
SOURCE: why does my xbox 360 make a loud noise when turned
try putting it into your TV if you have inputs and if you dont have any on your TV try a VHS player and put them in and scroll down to the channel L2 it will say that on the top right corner of the screen
Posted on Jul 29, 2009
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
HDMI won't work
Try a new cable.check no debris has lodged in the port for hdmi or at the cable.
Jan 29, 2015 | Televison & Video
I am not getting a signal on my tv when I connect to the receiver using an HDMI cable. What do I do?
First eliminate sources. For example, test another source like a dvd player / xbox,playstation gaming system, etc. If your tv recognizes these sources then it is a problem with your reciever and not the tv. If the tv does not recognize the other devices you tested then the hdmi port on your tv is bad.
Jul 29, 2010 | Vizio VO47L 47 in. LCD TV
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Sep 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
Receiving "Unlock" message and "Not Used" on my reciever
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock" and you will get sound. The only purpose for the HDMI jacks on this reciever is to give you a bonus HDMI jack so you only have to use one on your TV. I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's.
Dec 30, 2008 | Sony STR-DG520 Receiver
No picture
try using different A/V cords or a different tv. if your hooked up to HDMI then you should just try using a normal A/V tv and see how that goes.
Oct 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
125 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
