Question about Ovens
Diplomat select 620 fan failure
The fan for the oven has failed. Is this an easy repair? and are replacement fans easily obtainable.
  • Ovens Master
  • 3,463 Answers
You should have no problem getting a replacement fan motor.
You will have to gain access to thr rear of the oven to change it, but it is usually a straightforward repair.
Please rate my solution.
Thanks.
Posted on Nov 17, 2009
My Diplomat ADP3300 fan assisted oven has been turning off when trying to heat up, but has now completely turned off. I am an electrician so have checked the obvious stuff but not sure what I'm looking...
I'm an electrical engineering technician college dropout. :) But i have had 30 years experience troubleshooting and working on electronics and appliance repair on occasion. I would look for the circuit board. It could have burned circuit traces or a failed voltage rectifier. Sometimes the whole board just needs replacing. Most boards that have relays have relays arcing and sticking inside at times too. If it isn't that then there is not much more than a thermal cutoff that could be the problem. They can be tested for open circuit easily. Also if the fan ever stops turning the thermal cutoff could be a safety feature to prevent overheating.
Nov 08, 2013 | Ovens
I have a diplomat fan oven. I repalced the fan element about six months ago. everything worked fine, however in the past couple of weeks the motor has been running slowly and erratically. now something has...
Sounds like the fan motor has failed altogether, and as a result the oven element has probably blown again due to overheating of the element.A ew fan and element is more than likely going to be needed to correct the problem.
Dec 16, 2010 | Ovens
Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Apr 03, 2010 | Belling XOU174 Electric Single Oven
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
The oven turns off after 30 mins
Is the clock re-setting and flashing? Either the fan is failing and the oven is overheating, or the thermostat is faulty and the oven THINKS it is overheating. It is a fail-safe kicking in, momentarily cutting power to the oven to avoid lasting damage.
Set the time on the clock and the oven should be okay to go again, but if problem repeats, replace the fan and/or the thermostat - it is difficult even for an engineer with all his equipment to diagnose which of the two is at fault, but its about all there is to go wrong on a gas oven.
Apparently!
Jul 01, 2009 | Whirlpool RBD305PD Electric Double Oven
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Diplomat Select 620 single oven and no instructions
how do i remove the door to reseal the glass
May 14, 2008 | Ovens
Manual for a Diplomat Select 620 single oven
Sent the manual to you Tuesday the 18th.
Mar 09, 2008 | Ovens
Ovens Logo
544 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
