Question about Mitsubishi WS-55513 55" Rear Projection HDTV
When using over the air antenna, picture is unstable. When using any of the RCA jacks, no signal is received. Is there somthing specific that can cause this?
    Sergeant:
  • 470 Answers
On the signal board there is 4 surface mount transistors. There is one right by the input board (BA09), i would check the corresponding caps and diodes close to it also. I would replace all of the 4 transistors. If this SMT starts to go you will see wavy lines in your picture than it will go away in 3 min or so and get worse over time until no picture is seen. When it totally fails you will have no inputs what soever but you will have an OSD screen and when you choose DTV you will get a scrolling picture.
Posted on Nov 25, 2009
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
Need to know how to change and setup for use of antenna
Purchase your UHF/VHF antenna. The antenna can also be purchased at most electronic and retail stores. Consult your list from Step 1 and see how powerfulicon1.png the over-the-air signals are for your specific address. Purchase your antenna based on the broadcasting power you need to receive a clear picture on your TV. You might be able to get away with an indoor antenna if your signal strength is strong enough. If not, you'll need to purchase an outdoor antenna.
  • 4 Install your antenna (or have it done professionally) according to the building codes of your area. If you must use an outdoor antenna, it is a good ideaicon1.png to have the antenna professionally installed. This ensures that it is properly grounded on your roof, not too close to electrical wiring and stable during inclement weather.
  • 5 Hook the converter box up to your television using the cable that came with it (F Cable). Hook your antenna up to the converter Box. Turn on your TV and converter box. Tune your TV to channel 3 and press "Scan" on the digital convert box. Allow the box to scan for your available channels.
  • 6 View your picture and adjust your antenna accordingly for the clearest over-the-air feed. You should only need to make adjustments once. If you are having a difficult time getting a clear picture, use a signal strength indicator to see where you receive the most powerful signal.
  • Read more: How to Replace Cable TV or Dish TV With Antenna TV ' eHow.com http://www.ehow.com/how_5228282_replace-dish-tv-antenna-tv.html#ixzz2RrACTyTI
    Mar 29, 2013 | Sansui 19 in. LCD TV
    I cannot get a picture on any channel. Not hooked to cable. No antenna. What is the problem?
    Most of the TV sets have " Picture Mute" feature which means; if no signal exists on either Antenna plug or on Video input (RCA jack) no picture at all.Blank screen..no audio as well..all MUTED..
    to test it ,play a DVD ,you must have pictures and audio together..
    Use an antenna ( even a piece of plain cable will work ) ,and run "search" ,you must receive some TV channels thru AIR.
    Take care and please Remember to rate/vote for us to
    continue f
    or Helping out the Community :)
    Jul 09, 2011 | Toshiba MD13N3 13 in. TV/DVD Combo
    I need to know what cables to get to make it true HD. Also I wanted to know why I can't receive local channels.
    go to menu then tuning,set from cable to air,for local channel.you can't get true HD for cable because cable is an analog signal
    Sep 07, 2010 | Televison & Video
    We bought a 20" analog/digital tv the analog channels come on fine but we it scans for the digital channels it says no siginal will we be able to watch it when the change takes place even though we can't...
    This could be caused by two different issues.
    • Digital signal reception is bad. The digital signal must be locked in, digital signal reception is either on or off (not like analog signal reception where you can receive a low signal and a fuzzy picture). You may need to adjust you antenna direction and height or obstructions around your antenna, reference the web site for your specific location (address) for antenna compass headings. http://www.antennaweb.org/aw/Address.aspx
    • Television is faulty, digital receiver is bad. Your new television has two receivers, an analog receiver and a digital receiver. A simple power surge will knock out your digital receiver. Make sure you have a quality surge suppressor connected to the television power and the antenna is properly grounded. Return the television for a replacement and purchase a quality surge suppressor.
    You must add a quality surge suppressor to your digital television! http://ezinearticles.com/?Power-Protection-in-the-Home-Theater---Use-of-Surge-Suppressors-to-Guard-Expensive-Electronic-Gear&id=41318
    Good luck.
    Jan 03, 2009 | RCA 20F420T 20" TV
    Troubleshooting vcr
    Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
    From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
    Aug 14, 2008 | Televison & Video
    RCA P52939 - Can it receive HD-Only signal? Is it Analog-Only?
    The P52939 RCA is a analog Standard TV you will need the Digital converter to receive digital signals
    Feb 10, 2008 | RCA P52939 52" Rear Projection Television
    Unstable signal
    Are you sure it says unusable signal instead of unstable signal.
    This means that you have the wrong input in place in the tv. If you got the original remote with it there may be an input button. on it. Some RCA's use 00 for the video input. If your cable goes directly to the antenna connector on the back you should get all channels when you do auto search in the menu provided you have the right input programmed. If you are using a cable box the tv must be on channel 3 or 4. video input uses rca cables red white and yellow to the proper input on the tv but there again the input must be set correctly. Possibly in the menu do a search there. Hope this helps.
    Dec 29, 2007 | GE 32GT660 32" TV
    Mitsubishi WS-55513 55" Rear Projection HDTV Logo
    70 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
