Compaq M700 laptop. Fails to power up. When battery removed, still fails to power up but battery LED gives a series of 8 flashes repeatedly. That is the only sign of life. I have another M700, so I know the power supply is good. Reason for removing battery is that the working M700 wouldn't power up until battery pack removed. Duff battery pack, on that one, I guess. DaveL
SOURCE: My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Posted on May 30, 2008
efs_perpends
  • 1996 Answers
SOURCE: HP Compaq nc6120 Fails to Boot
Here's a link to troubleshoot the startup of your notebook, from the HP online support site, and another link that explains how to reseat the ram, which is worth a try. Has it exhibited any unusual symptoms, blue screens, etc. recently? It sounds like either some kind of hardware conflict, or a bad power supply.
Unfortunately, the nc6120 has its internal power supply on the system board and can't be changed separately. The part #s and removal/replacement instructions are in the service manual, link here. This is a somewhat widespread issue, and if you're still covered by warranty, I recommend you get it in for service. Otherwise, you or a reliable tech could start selectively unplugging hardware and see if that is indeed the problem. See links to similar posts here.
Best of luck with it. I hate to be the bearer of bad news, but have it checked out before you buy a new board.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 20, 2009
cheap to fix
  • 404 Answers
SOURCE: Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Posted on Aug 01, 2009
  • 7 Answers
SOURCE: hp compaq nx6125 fails to power up with mains or
i think is your bios battery(it is found on your board i dont know the type of system that you are using but just check for the silver battery and change it
Posted on Feb 08, 2010
djbr1ck
  • 158 Answers
SOURCE: E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Posted on May 12, 2011
Yellow led blink 8 times compaq m700
I'm not understanding what the problem is. If the battery is dead, and you remove it, how do you expect it to recharge? Why would you remove it? So, you take it out and nothing happens.So? What were you expecting to happen?
Before you do anything more, read the documentation that came with your laptop to learn how to care for your battery. The amber light usually blinks with the battery is running low. When you plug in the A/C adapter, the light usually becomes steady to indicate the battery is charging. At tleast until you remove it.
Hope this helps. Please rate this repsonse
Randy
Aug 31, 2012 | Compaq Armada M700 Notebook
Have a hp g60 -117us laptop after a bios flash laptop will not show a display it is only a black screen and only lights on when its turned on is power,touchpad and the first led that has a sympol of a...
Why did you flash the bios? Did you flash it with an upgraded bios that you downloaded from the HP Compaq site for your model and your operating system? When you turn on the laptop immediately start hitting the F8 Key repeatedly to see if it shows you the SAFE Mode option. If so select Safe Mode and see if it boots.
Are there any blinking lights or beeps? This is very strange. Try removing the battery and the power cord, then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and see if it boots. If it does you had a static buildup in the laptop and you released it by holding the power button for 30 seconds. If it boots, put the battery back in.
if all fails you can try to see if your system will go into System Recovery when you press the Power Button immediately hit the F10 or F11 keys repeatedly. If so you can set your system back to the way it was when your purchased it. That means you will lose all your data, documents, music, pictures and videos.
Mar 21, 2012 | HP Compaq 6735s Notebook PC KS088UTABA$247...
Hp compaq nx6125 fails to power up with mains or battery, battery led flashes 8 times after power switch is pressed,
Feb 08, 2010 | HP Compaq nx6125 Notebook
Flashing power lights green and amber will not power up
Try removeing the battery form the laptop and using just AC porwer. if it still fails you may need to replace the motherboard. :(
Sep 14, 2009 | Compaq Armada M700 Notebook
Stuck in standby
Have you held down on the power button for more than 10 seconds to be sure the unit is off?
If not unplug power cord and remove battery if all else fails
Nov 23, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Oct 31, 2007 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Oct 30, 2006 | Compaq Armada M700 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
