Question about Briggs & Stratton Garden
Model 135212, Type 002301, Code 95041112D used on leaf blower special rig. Engine had starting/running problems so Carb/Tank assy. removed for cleanout and carb diaphragm replacement. Where can I find a carb linkage diagram? My problems are with governor related rods. I am 83 years old and have worked on B&S small engines for years but I goofed on this one in not making linkage photos or diag. I am mad as Hell at myself for not being able to figure it out and 6 year old kid next door is only an expert on computers! TXhanks. **** Husta Wilton, CT
  • 1 more comment
  • husco Nov 17, 2009
    Jerr,thanks for the fast comeback. I apologize for mot providing B&S name with problem. I have some docs on this vertical engine, but nothing clearly shown for carb linkage. Let me look at B&S site tmw. and I will get back to you-assuming it is clear what messaging process entails.
    **** H.
  • husco Nov 18, 2009
    Jerr,
    Followup to our exchange yesterday. First some clarifications re goofs on my part.
    Yes, engine Model 135212 is a horizontal B&S 5HP. I have searched B&S website and various forums but nothing on carb linkage setup. Only exploded views, etc.
    I need help only on the two long rods wich run vertically up the back of the fuel tank from the governor, and(I assume) from a movable plate on the back of the fuel tank support bracket. These long links differ in diameter, 0.120" and 0.070". There is a spring running from the governor arm to the moveable plate on the back of the tank bracket.
    How do the two long vertical links attach to the governor arm, and to the plate on the back of the fuel support??? No prob with top of carb linkages. The larger dia. link snaps into a plastic piece on the carb.
    **** H.
  • husco Nov 20, 2009
    Jerr,
    Bingo! Thanks for your help. My engine OH days are rapidly coming to an end withthis memory experience.
    Have a great Thanksgiving and Christmas.
  • 78 Answers
SOURCE: I have a 9hp Tecumseh engine on my Sears chipper
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Posted on Oct 22, 2009
  • 110 Answers
SOURCE: I have an old tecumseh 10 hp eng model vm100. with carb problem
Rigid link to the top hole on govenor arm, spring link to second hole. If engine 'hunts', try the 3rd or 4th hole. Each lower hole will take off a few rpm, but make the engine less prone to 'overshoot' the goverened speed.
If you have not disturbed the govenor arm clamp where it fixes to the shaft that goes into the engine, that should be all you have to do if you have, proceed as follows ;-
Assemble as above. With engine OFF, loosen the govenor clamp. Push the end of the govenor arm so the carb throttle is wide open. Whilst holding it there, rotate the shaft in the same direction as the arm would have rotated it if you hadn't lostened the clamp. Ensure it's rotated as far as possible (this removes ant 'lost' movement in the internal govenor mechanism.). Now tighten the clamp and release everything. Push the speed control to FAST. The throttle should open, and it will requirer about 4 OZ of force on the end of the govenor arm to close the carb throttle. This force will be generated by the govenor when the engine is started
Move the speed conrol to SLOW. Most of the tention should disappear, allowing the throttle to close with very lettle pressure on the govenor arm.
If all this behaves as described, you should be safe to start.
Posted on May 12, 2010
#1 Taper
  • 1040 Answers
SOURCE: Briggs engine,carb on tank. runs
Here is a link to a couple of my Tips. And even though they are for weed eaters and such, the same concept applies to your carburetor. The key to carburetor cleaning is the Den Tek Brush!
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
And depending on how bad your corrosion is, you may end up needing to buy a new carb. Corrosion may keep the parts from moving freely; such as the float.
Good Luck!
Jim
Posted on Oct 01, 2010
  • 110 Answers
SOURCE: craftsman917270930 fuel pump not working &do
The fuel pump is part of the carb. It is best to replace the whole thing rather than trying to repair, but your choice and your money. Usually I take digtal photos or at least draw a sketch before tear down of something new so I know how it is supposed to go back together. If you already have it tore down my best suggestion would be to pick up a B & S shop manual and they have some pretty good diagrams in the governors section as to where the linkages should hook up. I've done a bunch of these but can't describe it.
Posted on Oct 24, 2010
aquaman987
  • 927 Answers
SOURCE: My MTD riding mower, 12.5
Try clearing the gas cap vent holes!
Gary
Posted on Aug 18, 2011
Testimonial: "Yes, that corrected the problem - Thank You very much. I was surprised, as I never had this problem before im my 35 years of mowing!"
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
How much oil to fill for oil change
if its a 5 hp engine fill to top of thread on fill hole
Apr 12, 2014 | Briggs & Stratton Garden
Have Stihl model Br400 Backpack the problem is the engine will not reach top rpm.
The oil to gas ratio is off - you need to either dump the fuel or run all the fuel out of the unit clean the carb and tank - replace the plug and filter mix gas and oil to correct ratio start and let run for 10 to 15 minutes - your carb may need to be adjusted as well.
Jan 08, 2013 | Stihl BR400 Backpack Leaf Blower
Poulan model: PPB430VS leaf blower. Won't start.
I think that those are suppose to be caps over the screw to discourage inadvertant tinkering with it. That way it is a deliberate act to get to them, if it is what I think it is.
Aug 08, 2011 | Poulan Garden
Yard broom leaf blower will not stay running I
It seems that the carb is not getting fuel. It could be a cracked fuel line. The fuel priming bulb could also be cracked/dry rotted. Possibly the fuel pump in the carb is bad. The carb is rather intricate and not something anyone without training should try to repair. The overhaul kit will cost $15 to $20. I suggest you take the blower to a repair shop.
Apr 19, 2010 | Homelite 'Yard Broom' Leaf Blower
Will not pick up gas into carb. will run when use starter spray in carb buts quits after short run
Check the fuel lines from tank to carb. for craks kinks and if it has a cutoff valve make sure that is working properly. Not sure what type of carb. you have ie. zama,walboro,ect. but the mixture needles need to be reset.If that doesnt work the fuel diaphram in the carb may be bad.
Dec 26, 2009 | Husqvarna Backpack Blower, Model No. 356bt
This Model 358-797251 Leaf Blower will not start. What can I do to make the engine run at the regular speed?
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Oct 19, 2009 | Craftsman 4 Cycle Blower/Vac
Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Sep 28, 2009 | Ryobi Backpack Blower 25.4cc
Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Nov 15, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Craftsman leaf blower
Hi
Check the fuel lines,fuel filter and clean the fuel tank.Disassembly the carb and clean it carefully.Diafragm type carb has a fuelpump,pay attention to it ,has to be tighten not folded.When the engine gets warm ,the fuelpump cannot keep the right proportion of fuel and the air/fuel mixture is changing.It has to be changed.
regards savumihai71
Nov 09, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
119 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
