Question about Samsung Eternity Cell Phone
Eternity touch screen does not respond to touch; phone is completely useless as is. It still powers on and appears to have full function, but there is no ability to input information; enable bluetooth (to copy data out) or to confirm all contacts are stored on sim card instead of internal memory. Any ideas/assistance would be greatly appreciated. also, does anyone know if using a data cable would enable pc control of the phone?
My touch screen not working SAMSUNG A867 ETERNITY
If you have any functionality at all left to your touch screen, try to recalibrate it within the settings menu. Otherwise, remove the battery, wait about 15 seconds, then reinstall.
If that doesn't help, the touch-sensitive surface glass has gone out. Apparently, this component in the first-generation Eternity has chronic failures.
Replacing it is not too much trouble for an experienced cell phone technician. But, it's not for anyone who doesn't like to tinker with small things. Here's a video demonstrating the entire process: http://www.youtube.com/watch?v=QJpHHs9QM5U.
Jan 23, 2011 | Samsung Eternity Cell Phone
On my samsung eternity, the touch screen wont work. i can do anything but touch the screen it wont work! how do i fix it?
Hey buddy,
The issue can be with the flex of your phone that connects to the touch screen. The connection might be loose thereby disabling the touch screen functionality.
The best solution is to take it to Samsung repair shop and get it repaired by an expert. They are well experienced with touch phone firmware malfunction issues.
Thanks!
Dec 14, 2010 | Samsung Eternity Cell Phone
When i turn my samsung eternity on it goes to the home screen but then the screen goes black and turns off. this has been happening for about a week now and occasionally i get it to work, but i dont know...
The screen saver is set to save mode. use the settings functionality of disable or reesatblsih system settings. a possible battery full charge after powering off device completely shoudl provide the capacity to hold splash screens with phone call display all at once.
Dec 04, 2010 | Samsung Eternity Cell Phone
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
The touchscreen on my samsung eternity frooze./..can not access my phone because the screen is frozen
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jul 06, 2010 | Samsung Eternity Cell Phone
I just put a new screen and face plate on my samsung eternity and the screen is working but the touch part is not working
TOUCH SCREEN
Take care
Jun 24, 2010 | Samsung Eternity Cell Phone
My touch screen isn't responding properly. For exmple when i touch the number one, my phone puts the number 2 on the screen. The screen freezes and sometimes doesnt allow me to do anything
hello;
here are some guild line that will help you in maintain your phone
you need to be careful on how it drop from you
you should allow your phone to do one function at a time (i.e)one after the other
solution to solve your phone problem
your phone key need to be celebrate
then how you have to celebrate the phone key is from the screen of your phone at the right Conner of the screen click on it as it move from one position to another till it congratulate you then put off the phone for some tine and put it on in a short time
then your phone will respond to your command
Good luck and thank for using fixya.
Apr 06, 2010 | Samsung Eternity Cell Phone
My Eternity won't let me calibrate...and the right side of my screen will not respond to my touch
This is a hardware issue. You have to take it to maker. If it's a new product, claim for the warranty.
Dec 01, 2009 | Samsung Eternity Cell Phone
Samsung Eternity  Cell Phone Logo
129 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
